You may also like
Race Cage
Adjustable Carbon Fiber Seat and Headrest
Ships next business day
Fit and Specifications:
Max Width at Shoulders: | 22.9 cm (9 in) |
Max Width at Seat: | 26 cm (10.25 in) |
Min Width: | 19.4 cm (7.625 in) |
Max Adjustable Length: | 80 cm (31.5 in) |
Min Adjustable Length: | 63.5 cm (25 in) |
Includes headrest, mounting hardware and velcro. Does not include seat pad.
- Two-Piece Adjustable Carbon Fiber Seat
- All Required Mounting Hardware
- Ventisit Seat Cushion
- Headrest and Cushion
Installation Resources:
Vendetta V20c Recumbent Bicycle Racing Jersey
Ventisit
