Indoor Trainers For Cruzbikes
Robert Holler shares tips for outfitting your Cruzbike indoor training setup.
No doubt that getting outside to ride your Cruzbike is the ultimate experience. But sometimes it isn't possible (think the recent -50F temps in the midwest) and you need to take your riding indoors. Moving to an indoor setup is easy on a Cruzbike and we are here to help!
A question that comes up often is, "Which trainer should I buy to use with my Cruzbike?" There are a lot of choices out there for trainers - all of which feature a wide array of options and technology.
Actually, if you have not been riding a trainer for many years, it might surprise you now. The technology that has gone into training indoors is amazing and now much more fun with the advent of companies like Zwift that allow you to virtually ride and train with people all over the world. Your training can now be a fun and social experience as opposed to the old days of mindlessly spinning alone on a noisy trainer.
I don't want to specify any individual brands as a recommendation here, but following a few simple rules will get you headed in the right direction towards  trainer setup that you will be very happy with. The biggest hurdle to keep in mind is compatibility.
There are many types of trainers, but the key is how the bike mounts to it. Here there are two main types: direct drive and wheel-on.
Wheel-on trainers hold the bike via the drive axle usually using a special skewer included with the trainer. The bike wheel and tire itself is what drives the trainer.
Wheel-on indoor bicycle trainer
Direct drive trainers require you to remove the drive wheel from the bike. The trainer itself has a cassette of your choosing installed on it and the trainer basically replaces the drive wheel.
Direct drive bicycle trainers
In general, Cruzbike models with 700c forks and wheels, and the Q45, require a Direct Drive Trainer. Wheel-on type trainers are not compatible in stock form with these Cruzbike models. The reason is our wider front end. Cruzbikes of this design have a wider point at the drive axle due to the chainstay and use a custom width skewer. As you can see in the photo, the stock Cruzbike skewer is much longer than a typical rear skewer for a wheel-on trainer.
This added width means that the required skewer included with a wheel-on trainer will not be wide enough to use safely on the bike. In addition, the overall width at the front axle area will likely be too wide for the trainer to safely clamp closed anyway, even if you could fashion a longer skewer.
Cruzbike models that use the 26" fork, such as the Sofrider, Quest, Q459, QX100, and T50 can use either a direct drive trainer or a wheel-on trainer. The reason is that due to the fork design of these models, the front chainstay is mounted forward of the drive axle. The front axle width of these models is close to the same as the drive axle on any standard bicycle, so the special skewers included with wheel-on trainers will usually fit just fine.
Note - with all trainers and bikes, there is a risk of interference somewhere. Trainers are designed for upright bikes. The designs of the attachment areas on trainers is pretty universal, but the design of the rest of the trainer is not, and sometimes there can be interference with other bulky parts of the trainer on a Cruzbike such as disc brake calipers, etc. In some cases something like a disc brake caliper might need to be temporarily removed for an interference-free fit. This is rare however.
The Cruzbike forum is an excellent place to find advice from riders who use trainers all the time, as well as other fun training enhancements such as Zwift and TrainerRoad that can make training fun.
If you have any questions, email us at support@cruzbike.com and we can help make sure your indoor setup is something you will love to ride almost as much as riding outside!
7 comments
  • Xavier
    Thank you, good information posted. Need help, will a Saris H3 Direct Drive Smart Trainer work with an S40 bike and which cassette do I need to purchase. Appreciate any assistance, I am new to recumbent bikes, please excuse the questions. Thank you.
  • Mark
    So if I get a Tacx Neo Smart T2800 or a Wahoo KICKR Core will I still need a front skewer other than the stock one that came? If so where can this be ordered from? Thanks. I love the spoof the v20 and the comfort. After just a few months now I can’t wait to be racing again.
  • Wayne Harner
    Anyone know if a Silvio 2.0 will be compatible with a Kickr Snap wheel on model?
    Or would I need a direct drive model?
    Thanks in advance for helpful replies.
  • Hubert Dohr
    Does anybody know if the Wahoo Kickr snap skewer fits to the vendetta or is it to short?
  • Paul Cappiello
    A tandem skewer also works perfectly on the S40. Mine is mounted on a Kurt Kinetic w no problems
  • Maria Parker
    Thanks a lot for this Ray. Hope this can help other customers.
  • Ray Fonck
    I ran into the axle width and skewer problem when trying to mount my S40 on a CycleOps Fluid trainer (wheel-on trainer type). A solution that worked for me was to replace the disc drive wheel with a non-disc 700c drive wheel. The 130 mm dropout width of that wheel allows use of a standard trainer skewer with the S40 fork and chain stay. I have at least 5 mm of thread connection. Just an observation…
Leave a comment
Please note, comments must be approved before they are published
