Doug Burton's blog
Conversions: Axles, Hubs, Quick Releases and Adapter Brackets
Submitted by Doug Burton on Mon, 28/05/2012 - 15:24
Our conversion kits are designed to be versatile, fitting a variety of forks and accepting many wheel diameters. There are some subtilities to be aware of when using different types of hubs and axles for conversions.
Quick Releases and Axle Widths:
Our adapter brackets are made of 2.5mm carbon steel. These are quite strong, and making them thicker would make them unecessarily heavy. However, many quick release wheel stub axles are designed for aluminum dropouts, which are usually 5mm thick. An issue can arise where the quick release nuts do not have a deep enough relief, bottoming out on the stub axle before the QR can bite into the dropout (adapter bracket) properly. The QR will seem to tighten up very hard, but the nuts will not bite; allowing the axle to slide in the dropout slot on the adapter bracket. This can bend the bracket, as the differing loads on the wheel form the road and the bracket from the chainstay/pedaling combine to stress the bracket. Solve this by filing about 2mm off the hub stub axle on each side. Also, position the axle ahead of the rearmost point of the dropout slot. (This will also give your chain more operating clearance.)
This picture shows things done the wrong way:
The axle is all the way to the rear of the slot, and the QR has only bitten into the paint on the adapter bracket. Subsequent to this photo the axle was filed on each side and the front end of the bike became more rigid as a result.
MTB Hubs vs. Road Hubs
Bike wheel hubs are characterized by a measurement called OLD - Over Locknut Distance. MTB (and 29'er) wheels use an OLD of 135mm, and road wheels (650c and 700c) use an OLD of 130mm. The OLD is the same as the dropout spacing across the axle. Our adapter brackets change the front fork OLD of 100mm to an MTB OLD of 135mm.
If you use road hubs of 130mm OLD, you should place a 2.5mm washer between the fork and the adapter bracket (where the attaching bolt goes through) to match the bracket width to the hub width. The chainstay will still be looking for 135mm, but the nylon spacer washers that match the chainstay to the adapter brackets will tolerate this alignment in the front.
While bike parts tend to follow certain conventions, MTB and Road conventions are surprisingly different and it helps to understand these when mixing and matching parts to create your perfect Conversion Bike.
Sheldon Brown's site is a wealth of information about these small but important facts.
Ride Happy!
Doug
Doug Burton's blog
miakana's picture
Nice comparison of hubs. This
Nice comparison of hubs. This really expands my knowledge about bikes. purchase soundcloud services
Jon Austin's picture
Found this on the trash pile
Found this on the trash pile down the road. Is this a suitable donor frame ? note the welded cross bar by the shock.
 26" Men's NEXT Shocker Mountain Bike
http://www.kaboodle.com/reviews/26-mens-next-shocker-mountain-bike
Kyytsis's picture
Hello Doug, I believe this is
Hello Doug,
I believe this is done by you: http://s153.photobucket.com/albums/s218/db1488/?action=view&current=IMAG03221.jpg
Could you tell what is the frame that is used here? The rear fork looks interesting. I believe this is not done with the standard Conversion Kit?
Ville
Doug Burton's picture
Hi Kyytsis, I apoligize for
Hi Kyytsis,
I apoligize for responding slowly; I have just returned from China and still have jet lag.
That is a Walmart Tiara frame with a K2 carbon swing arm adapted. The conversion kit has been modified to accept a 28.6 mm tube in the lower front tube, and a Silvio pivot clamp is used.
I've not completed this as the drivetrain parts have been moved to a Silvio 1.5. I intend to complete it with other components soon. A fork with more rake will be needed (which I have in the parts bin).
The Tiara frame is very versatile, and converts very well. It modifies easily for many conversion applications.
Doug
8253761's picture
I’m a new convert to
I’m a new convert to recumbents due to a back injury combined with the need to keep fit.
I've recently purchased a Quest 1.0 complete with BB7 all around. I'm getting used to the intricacies of riding.
I’m interested in the cost of retrofitting to V 2.0 specs. This should assist the newer riders.   I think you would also get some good follow ups from developing a retrofit kit.
Love the Silvio / Vendetta style.  Can you fit a Silvio boom to a Quest - What’s the impact?
Many thanks for your thoughts/ advice.
Happy to discus offline if necessary
Phil Hartwig's picture
Could you send me some
Could you send me some pictures of the front wheel assembled in the correct position
John Tolhurst's picture
Go through the forum,
Go through the forum, Paul. http://cruzbike.com/forum
Kevinosbern's picture
I have been thinking about
I have been thinking about converting my Y-frame bike into a Cruzbike, after I saw an article here in this site itself that is actually a possible thing. But getting the right components and parts is the challenging part in this.
elder care las vegas
