disc wheel for the drive wheel
I want to get a drive wheel for our Sofrider that will take a disc brake. Any recommendations? Also would appreciate recommendation for disc and brake. What is on the QX100?
-Cliff
I did a LOT of research on disc brakes when we were contemplating them for the first version of the Quest. I built several Sofriders with front and rear disc brakes to look at the ins and outs.
I designed a rear caliper adapter for the Sofrider swing arm, and designed it so the only tool you needed to make it was a drillpress.
If you want, I can send you a drawing rendered 1:1 scale that describes the correct aluminum bulk material and includes a template you can print on label paper and just stick on the aluminum to guide your center punching and drilling.
Sofriders work very well with disc brakes...
