Foldie as Donor
Discussion in 'Conversion Kit' started by Ken_1, May 26, 2014.
  1. Ken_1
    Ken_1 New Member
    Hi guys,
    After seeing the posts, I'm 90% hooked on converting my foldie into a bent. Would like to hear if my foldie is appropriate for the conversion.
    https://www.dropbox.com/s/uentfa585sjbj4k/CameraZOOM-20140525242457662.jpg
    As the foldie comes with disc brake, I guess it will have to go. I will be using a Tektro R559 to replace the disc brake. Seatpost will be either grind down or replaced.
    I hope end of the "project", i would still be able to keep the full foldable-ability while having such an unique bike.
    Thanks.
  2. chrisblessing
    chrisblessing Well-Known Member
    folding conversion...
    Hi Ken,
    As you know, there are at least 3 of us who have successfully converted folding bikes. Charles, Shahmatt and me. I think your donor has potential, but I'd be concerned about the mid-section hinge. It protrudes above the top tube which could be an issue. That said, if the conversion seat mount can rest between the hinge and the seat post you should be fine. With the seat positioned that far back a lay back seat post would be a necessity to give you the right seat angle.
    If you're willing to do a bit of machine work you can even keep the folding stem. I can let you know what I did with mine to achieve this.
    And, of course, you're right about the disc brake.
    Good luck with this. If you can build a compact conversion you'll not regret it.
    Chris
  3. Ken_1
    Ken_1 New Member
    Seat location
    Thanks Chris for the comment.
    You mentioned placing the seat position between the hinge and the seatpost.
    Will it be better if it is placed between the hinge and the handlepost? At least 1 advantage I can think of is that the handle bar will be closer to me and not obstructing the leg-knee movement.
    Appreciate any comments, especially related to foldie conversion.
    Cheers, (will be placing the order tonight after work)
  4. Vargas
    Vargas Well-Known Member
    The conversion kit costs
    The conversion kit costs US$400. There are two Quests for sale for US$750 each. I'd rather buy one of them.
    After all it won't be a foldie after the conversion, or at least no so easy and quick to fold.
  5. Charles.Plager
    Charles.Plager Recumbent Quant
    Hi,
    Short version: You're
    Hi,
    Short version: You're good to go.
    Long version:
    Yes, you'll need to do something about the front brakes. And, yes, you'll need to do something about the front stem. (I do recommend looking into what Chris did as this would be a very nice feature to have that I don't. I do worry about the stem being strong enough as you can put a lot of torque on it when your pushing hard.)
    Personally, I'd put the seat pan between the hinge and the head tube (that's what I did). I wanted to be able to have a lower seat angle and having the seat pan move forward is necessary for that.
    [​IMG]
    [​IMG]
    Vargas isn't wrong: those are good prices on the Quests and depending on what you want, that may not be a bad option. In my case, I can take a folding bike on the train it takes me 60 seconds to get my bike small enough for that. A Quest would take a lot longer (I will say the fact that the Quest 451 fits in a single suitcase is mega-cool! I need to try that with my bike at some point :D).
  6. Ken_1
    Ken_1 New Member
    Good to go
    Thanks all.
    Placed the order and all set to go.
    Will take pics along the journey and hope to see some beautiful transformation.
    Cplager, nice sweet foldie.
    By the way, i will be using stem adapter to lift up the handle post clamp & place the conversion arm under.
    Hope that way, I should still be able to fold the handlepost.
    Wish me luck :)
  7. chrisblessing
    Good to go...
    Hi Ken,
    Sadly, the two Quests are gone. I almost got them but the seller found a local buyer for both.
    Charles is right about the seat placement. I'm tall, and have my seat mounted as far back as I could get it. Any further forward and I'd be riding a plow
    [​IMG]
    Good luck with the build. Keep us posted.
    ps. By the way, my foldie is still a foldie, and takes only a moment to fold. A bit more time and it fits into a suitcase.
  8. Ken_1
    Ken_1 New Member
    Work in progress
    Been weeks since i got the kit and still progressing slowly due to lack of parts.
    Anyway, let me share my progress and enjoy the fun.
    Sorry for the link as I can't upload as embedded pictures.
    This is the "package"
    https://www.dropbox.com/s/y7ibz5j9ya1cxl2/CameraZOOM-20140605184458842.jpg
    Still raw
    https://www.dropbox.com/s/v8fkrf3wspupml4/CameraZOOM-20140607113509060.jpg
    BB, crank, and seat post done
    https://www.dropbox.com/s/rouh74bdcqio14d/CameraZOOM-20140609195417744.jpg
    Made some modification on the kit seat pole clamp and used back the original pole.
    Tested out the limit of the recline angle
    https://www.dropbox.com/s/6i9ou8v3vpcm2mo/CameraZOOM-20140614202139857.jpg
    https://www.dropbox.com/s/wwgae2wo7xzrngh/CameraZOOM-20140614202301483.jpg
    https://www.dropbox.com/s/1qvpchiwtbsb1ro/CameraZOOM-20140614202234435.jpg
    Copied the idea of using butterfly nut to screw/unscrew the support from the seat. Good idea, Charles (Cplager)!
    https://www.dropbox.com/s/ijz1qq4dusy9l6g/CameraZOOM-20140614202607515.jpg
    The foldie folds
    https://www.dropbox.com/s/rozu2f1xb386xsz/CameraZOOM-20140614202525541.jpg
    As the existing handlebar hit the knee, Im waiting for a new handlebar, brakes and etc to make it good.
    Cheers and great thanks to the community for the support.
  9. Charles.Plager
    Nicely done, sir!
    Now get
    Nicely done, sir!
    Now get outside (with new handlebars) and ride that bike. :D
  10. Eric Winn
    Eric Winn Zen MBB Master
    I agree with Charles, nicely
    I agree with Charles, nicely done! I like the colors too. Keep us posted on your riding progress.
  11. Ken_1
    Ken_1 New Member
    Thanks guys. im as eager as
    Thanks guys. im as eager as well but need another 1~2weeks to get the parts in..
    Till then, I can only try to peddle at home. lolz
  12. Shahmatt
    Shahmatt Active Member
    Hey there,
    Nice job!
    What
    Hey there,
    Nice job!
    What parts are you waiting for to get started?
Share This Page
