SlowRoll1950
My idea of simply moving my old mountain bike wheels/tires to my frame build went bust because the wheels are neither quick release nor have disc brake mounts. So I ordered some new wheels. When they arrived yesterday, it was visually apparent that they are about 2/3 the width of the wheels they are replacing. I wrote to the online supplier complaining that I ordered 26" x 1.5" and was sent 26 in wheels that were 19mm wide. Here is their response:
From the information provided it looks like you did receive the correct items. A 26 x 1.5 wheel will not measure 26 x 1.5". This is normal. The wheels that you ordered should have a inner width of 19 mm [.]
You did order and you did receive a 26 x 1.5 wheel. A 26 x 1.5 tube and tire should fit on the wheel that you received.
I have attached photos both the new and old wheels that show their respective widths. The tires I took off the mountain bike say: 50-559 26x1.95 to fit HB-575 rim. I have also attached a photo of the detail specs included with the wheel. My question is can I put these tires on the new wheel? If not, what should I have ordered instead of what I did, or is the vendor lying to me?You did order and you did receive a 26 x 1.5 wheel. A 26 x 1.5 tube and tire should fit on the wheel that you received.
