New and Improved Headrest Clamp
Discussion in 'Innovators Workshop' started by RojoRacing, Mar 23, 2016.
  1. RojoRacing
    RojoRacing Donut Powered Wise-guy
    I was wondering what ever became of that conversation I had with the powers to be. I never heard back about whether or not they secured a line on mass producing the clamp for future bikes. I'm sure some out that can make them for pennies on the dollar it cost me.
  2. ratz
    ratz Wielder of the Rubber Mallet
    We got the to pet the prototype at the retreat; the elegance of your design was a point of discussion to highlight the contributions owners make to the product line evolution.
    super slim likes this.
  3. DavidCH
    DavidCH In thought; expanding the paradigm of traversity
    If Jason carries on as being Jason, I think I will frame mine and put it on the wall.
  4. bazzawill
    bazzawill Well-Known Member
    Hi
    I would be interested in how that conversation went. I would like to think the ingenuity of our communities engineers are being rewarded. Unless it is covered by NDA
  5. Itripper
    Itripper Member
    What is the weight diff between stock and this clamp?
  6. RojoRacing
    no idea, I don't have the stock one handy anymore and I have no more new ones at this time to weigh.
  7. Ivan_Liew
    Ivan_Liew Member
    I've been been using the Rojo clamp on my Silvio 2.0 for some time. It's definitely better than the original and reduces headrest movement and rattling when I hit a bump - so it's not only for ease of adjusment.
    My Silvio only had one hole so I just used one bolt so far, and will consider drilling a second hole in my frame but it's not urgent. Now my seat is more firmly attached to the frame which is a plus. The only downside to this is that it is harder to take my saddlebags on/off but it's a small trade off. Highly recommended! :)
    Always-Learnin and Zzzorse like this.
  8. scabinetguy
    scabinetguy Well-Known Member
    Not that I have ever had a complaint concerning the stock head rest on the Silvio or Vendetta, I decided to make an "adjustable" head rest. I don"t know if Maria is still pursuing this design or not, she did have some interest a while ago. I made it out of an ADEM head rest pad and fastened it with a water bottle cage type mount. This mount makes it possible to adjust the head rest not only in and out but up and down. You can actually make quick adjustments during a ride. DSC_5449 copy.jpg DSC_5454 copy.jpg
  9. ReklinedRider
    ReklinedRider Zen MBB Master
    Very ingenious! Have been about to go the Thor seat mod route but think i will try your solution first. Thanks for posting.
  10. tiltmaniac
    tiltmaniac Guru
    Nice! I wouldn't mind getting two of those too! ;)
    If Maria and Jim don't decide to do this, hopefully they'll consider at least shipping with some modded screws (I got frustrated with this for my bikes and got some longer bolts which I modified to make a 30 minute long process of getting the seat on into a 30 second long process).
    I like the scissor-clamps from a mechanical point of view (not likely to squeak, etc), but as shipped stock with the short screws, they're a royal pain to deal with.
    If you're using(/have) only one screw, I wouldn't be surprised about the headrest rattling. It really needs two mounts (i.e. both clamps/screws) to be secure in both dimensions in which it might (attempt to) move.
  11. RojoRacing
    Ok so I'm officially off the hook and you guys and gals can order these direct from CruzBike. So sorry for making such a cool thing and then failing to keep the parts coming but such is life and it's struggles sometimes. Click here for your new improved headrest clamp.
    http://cruzbike.com/perez-clamps
  12. Charles.Plager
    Charles.Plager Recumbent Quant
    That is simply awesome. Well done, sir!
    tiltmaniac likes this.
  13. ReklinedRider
    As we say down south, that is pure-dee awesome!
  14. ChaleJake
    ChaleJake Well-Known Member
    Just installed my new Perez clamp. Easy to do. I did not drill the seat pan. Much better than the old scissor clamp. Well done, Jason.
    super slim and castlerobber like this.
  15. tiltmaniac
    tiltmaniac Guru
    I just got my Perez clamps recently, but they're a different design than Jason's original: these new ones have the connecting rod on the centerline of the clamp body, preventing the screw from going through the clamp body, and providing only about 3/8 of threading depth total.
    I find them very difficult to use-- you have to lift the clamp up in order to get the short (which is all that will fit inside the clamp body) screw to catch its first threads.
    With the provided screws, there is a good few millimeters between the bottom of the screw head and the frame top for the rearmost screw-- providing no clamping action whatsoever! While I'm not sure how else I could be doing it, I'm open to suggestions about how I'm doing it wrong...
    (It is entirely possible that, being an older frame, things have shifted...)
    And, before anyone asks, no, you cannot use a longer screw unless you wish to place many washers/spacers above the frame (where it'd poke holes into your spine).
    Any chance I can convince folks that Jason's original design (the rod which spaces the clamps out is to the side of the screw-hole) is superior, and we should go back to it?
    With that design, where the screw can poke out the bottom of the clamp, screw length is not nearly so critical...
  16. RojoRacing
    Sounds like the CruzBike version would be more difficult to install initially but it shouldn't be any harder to adjust the headrest after the fact. I'd be more worried about riders over tightening the bolt and pulling out the threads if too little thread engagement was used.
    So deal with it once and it should be equally good after the fact.
  17. super slim
    super slim Zen MBB Master
    Can you drill new hole in the clamps where Jason had them and move the rod off centre?
    Jason's rod location offers more resistance to the bolt tightening torque rotating the clamp!
    Can you take a photo of one of the new clamps, as I have just ordered one, so I can plan to modify it.
  18. RojoRacing
    Based on his description you could but it would only get you half way their. Repositioning the rod to the side would let the bolt travel deeper into the clamp so you could use a slightly longer bolt but you'd still need to drill thought the other side and add threads to have the bolt go all the way through. Also unless you bolt was long enough to pass through the original rod hole and grab those new threads on the other side you wouldn't be gaining any added thread strength. Most of this is easy enough for someone like me to modify be is beyond the casual riders tool box.
  19. ratz
    Email jacob@cruzbike.com about the problem and he can probably let you know if something is amiss with what you were sent. He designed the new one based on Jason's design. Normally this would got to support@ but in this one case it might be best to go to the source
  20. super slim
    I have drills, drill press, taps, and a range of metric socket screws, so full length bolts will be used, as I have a rear rack hanging off the headrest!
Share This Page
