The X01 Eagle has landed
Discussion in 'Bike trends, tech, and industry' started by JOSEPHWEISSERT, Apr 20, 2017 at 9:14 PM.
  1. Will this work on a Vendetta?
    SRAM X01 Eagle:
    - 12 cogs, 10-50T cassette: 10, 12, 14, 16, 18, 21, 24, 28, 32, 36, 42, 50.
    - Chain
    - Trigger shifter
    - Rear derailleur
    - Driver body
    Other things:
    Keep my 53T Q-ring.
    Only have one chainring.
    Remove my front derailleur, chainring shifter, and cable.
    Keep my 150mm crank arms.
    Keep my existing wheels.
    https://www.sram.com/sram/mountain/family/x01-eagle#sm.00000d460ct8aye0xyq9or5svdllk
    super slim and Mathew Fy like this.
  2. RojoRacing
    RojoRacing Donut Powered Wise-guy
    Drive wheel needs an XD drive for the hub which can be purchased aftermarket for premium hubs most the time. A Q-ring won't have the narrow wide teeth needed to guarantee the chain wont pop off in the event you hit a bit bump or pot hole.
    super slim likes this.
  3. Doug Kline
    Doug Kline Active Member
    A 53/50 combination would leave a lot of chain slack at 53/10. You'll need to look into how much slack the derailleur can take up. I have a 50/34 11-36 10-speed set up with a SRAM X0 long cage and the 34/11 combo rubs. That's asking the derailleur to take up 16+25=41 teeth. You'll be wanting to take up 40 teeth. You *might* not be able to run in high gear.
  4. ratz
    ratz Wielder of the Rubber Mallet
    What Jason said; you need a Rotor CX1 for single speed; that maxes out at a 46T but don't under estimate how big a jump a 10T is over an 11T.
    A 46x10 is almost as big of a gear as 53x11
    46x10 is 121.3 gear inches
    53x11 is 127.1
    53x12 is 116.5
    So the 46x10 is half way between the 11 and 12 on the 53. How offten do you ride in 53x11. If you have electric shifting Di2stats.com will tell the tale
  5. ratz
    Eagle derailleur has a super long derailleur and a pivot; as long as he's got that it will work. Remember no front derailler so that is 14T of capacity that isn't used by being in a little ring offset from a big ring.
  6. Doug Kline
    Good point. The derailleur has to take up the same whether you have a 38t chainring or 53t. I stand corrected.
  7. To start with: Aargh, the sods! I was up-to-the-minute cool with my 11sp cog and wide-narrow chainwheel, and now they've invented sodding 12sp, the sods!
    Rant over. Sram website says the Eagle cog is the same as the XX1 with an extra cog slapped on the side, which makes it wider. I had to add a washer to make the XX1 cog fit in my Silvio forks. Would the Eagle cog be too wide? I am told you should not spread aluminium forks. Does the trigger shifter fit road bars? Mountain bars do not fit the clamp on the slider. I went through the whole "road vs mountain" business and it is a test of mental stability.
    All that aside, my XX1 works really well. I have never had the chain jump off. I have a Raceface wide-narrow 42t. I almost don't miss my Grasshopper's Rohloff.
    I keep wondering about the elliptical chainwheel, but I do not want the chain to jump off. I discovered Garbaruk. This is a company that makes w/n elliptical. They call it a melon. I am wondering again.
Share This Page
