Torque settings
Discussion in 'Road Series (S1.x, S2.x, S30)' started by mickjordan, Mar 16, 2012.
  1. mickjordan
    mickjordan Well-Known Member
    Are there torque settings available for all the various bolts on the Silvio?
    I had an interesting experience today that suggests that my boom clamp isn't tight enough, although I thought it was (tightened by hand).
    I was doing a spin session with a short segment where you stand on a DF bike. On the Bacchetta I just used to increase my cadence, but I tried pulling on the bars on the Silvio and getting partly out of the seat. All fine but afterwards the front derailleur shifting was all messed up. My assumption is that I moved the boom with the pulling and tightened the cable. This would be annoying on the road!
  2. John Tolhurst
    John Tolhurst Zen MBB Master
    Mark position with tape
    It may be initial cable stretch and settling, or it may be movement at the boom clamp. Put some tape to record the position and keep an eye out for it gapping.
  3. mickjordan
    Pretty sure it was boom clamp movement because it was immediate; after pulling, when I tried to shift down to the middle ring, no joy.
    Still interested in torque settings though, e.g. for the chainstay bolts/boom clamp.
    Mick
  4. Doug Burton
    Doug Burton Zen MBB Master
    Torque Settings...
    ...are determined by fastener characteristics.
    This chart is very useful, in inch-lbs or NM:
    http://www.cncexpo.com/MetricBoltTorqueNm.aspx
    http://www.cncexpo.com/MetricBoltTorque.aspx
Share This Page
