Quest 20" Long Slider Option
SKU: CBQSLS
$45.00
This option is for the Quest 20" and is used to give an extra long leg adjustment.
With small wheels, there is plenty of forward adjustment of the boom before it touches the front wheel, so the long slider option makes the Quest 451 a bike even daddy long legs can ride, fitting an x-seam of nearly 1200mm, or 48". If you swap cranks out to something longer, another 20mm can be gained.
