Silvio Under-Seat Storage
4 replies [Last post]
BBL's picture
BBL
Offline
Just having completed my Silvio build, I have discovered there is not a lot of off-the-rack storage gear that fits Silvio well, short of adding a rack.  After thinking about it a little I came up with a simple, low-cost approach to add 3.6 liters of under-seat storage on Silvio.
I started out with Sofrider.  The Radical Designs Solo Aero fit nicely on the Sofrider – not so on the Silvio.  Searching the Forum for ideas, I found several options, but none that were particularly suited to my style of bicycling.  I am not a commuter.  My rides generally vary from 15 to 40 miles a day, locally.  I just need a little extra space.
I use plastic jars for under seat storage on my Silvio.  Each jar is a 4” dia. X 9” long cylindrical container.  Each provides 1.8 liters of storage.  I got them at Walmart.  It is what bungie cords are packaged into.  Similar jars are available on the internet but most are available only in bulk quantities.  Walmart was only too convenient, but boy do I have a lot of bungie cords!
I used only the existing holes in the Silvio seat to attach eyelets, then attached bungie cords through the eyelets.  The eyelets were purchased at the local hardware store.  Excess threads were trimmed with a Dremel tool.  I covered the nuts with electrical tape (not shown in this photograph) to preclude chaffing the seat fabric.  You don’t have to be much of a “handy-man” to do this.
The underside of the seat looks like this with bungie cords attached.
The finished product looks like this.  You can also customize the clear plastic jar by printing your favorite message or color onto a sheet of paper and attaching it to the inside of the jar.  Two of these jars can be mounted, one on each side of the seat.  On the right side of the bike my jar contains things that I hope I will never use on my ride (first aid, tire repair, batteries, tools, paper towels, CO2, etc.).  On the left side I have room for cell phone, wallet, jacket, etc.  On short rides I will cram cell phone and wallet into the right side container, too.
This implementation was at first inspired by a “Technical Tour” of the Vendetta by Jim Parker in which he described the austere manner in which Maria carried her tools – a tennis ball can.  A single container -- a bit bigger than a Maria’s tennis ball can-- has sufficient capacity for most of my rides.  The approach has the advantage of scalability.  I can add a second container to the other side or not.  One can be added to the seat back, or different sized containers can be used.  It’s easy to clean.  Although, the attachment is reasonably secure, I would not recommend carrying too much weight.  My tool side container (loaded) weighs 800 grams.  Yikes, that sounds like a lot!  As a point of reference, my filled 21oz water bottle weighs in at 700 grams.
The photograph below shows the jar without the logo.  The logo was printed on an 8 ½ X 11 sheet of paper on an inexpensive ink jet printer.
I like the Road-Runner image – Beep, Beep.  Sorry for the reflection across the image.  Oh yea, don’t try this on your diamond frame.
Finally, thanks to all who have posted to the Cruzbike Forum.  I have scoured the Forum for months gathering ideas and insights into this fantastic machine!  Hopefully, someone will find my post as valuable as I have found yours.
matthew's picture
matthew
Offline
Share
No, no! You're doing it
No, no! You're doing it wrong! See, you're supposed to claim to have revolutionized minimalist cycling with your amazing new product for waterproof storage. Of course you're willing to sell us your assembly kit for the low, low price of $45 (just barely enough to cover materials cost, of course), plus shipping and handling.
Seriously though, that's a pretty slick setup. Even commuters like myself need to carry tire patch kits, phones, and whatnot and this looks to be pretty well thought out. Do you have a problem with the loaded cans swaying at all, or are your bungees strong enough to keep it tight to the seat?
BBL's picture
BBL
Offline
Share
The bungies are strong enough
The bungies are strong enough to securely support the 800 gram load.  Add a lot of weight and it will begin to get wimpy.  I have not tested the limits, but I would suspect 1200 grams would be close to the limit for the small bungies that I am using.
BobD's picture
BobD
Offline
Share
A great use of space
A great use of space BBL....
Your use of bungies reminds me of what many do when building kayaks. I used this approach when creating an attachment for my Greenland Paddles.
I decided to use the Radical Bag with my Silvio....and it worked out well when set up under the seat.
http://cruzbike.com/underseat-location-radical-solo-racer-wide-bag-easy-...
Your idea adds the opportunity for me to increase storage space under the seat next to the bag if needed. Of course.....like with all recumbents the challenge is to not add too much weight as it so easy/tempting to do.
Many thanks and welcome!
Bob
Mark B's picture
Offline
Share
Way to think outside the box!
Way to think outside the box!  Great idea, but as you suggested, I'd worry a little about the bungies a little.  They do weaken after time.  Still a great idea!
