You may also like
Q Touring and Commuting Rack
Transform your Q into the ultimate commuter or touring bike with Cruzbike's rack specially designed for the Q. Made sturdy for fully-loaded panniers and trunk bags this rack is as robust as it is good looking. It is compatible with trunk bags, baskets, and panniers.
PRODUCT DETAILS
- Weight: 2.3 lbs (1.04 kg)
- Length: 25 in (63.5 cm)
- Width at Top: 5 in (12.7 cm)
- Width at Bottom: 10 in (25.4 cm)
VIDEO Q45 Installation: Q Touring and Commuting Rack Installation.
VIDEO QX100 and Q559 (Legacy) Installation: Q Touring and Commuting Rack Installation
Rugged Waterproof Pannier
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
Ventisit
Cygolite Dash 520 Head Light
LIGHT THE ROAD AHEAD.
Powerful 520 lumen head light great for Cruzbike recumbent bicycles. 24/7 Safety Technology® gives you a powerful selection of 8 night and day modes: Boost, High, Medium, Low, SteadyPulse®, QuadDRL Steady, Quad DRL Flashing and DayLightning®
- Low-profile, water-resistant design
- Weight: 79g
- USB-rechargeable internal battery
Origin8 Light Mount Stub
EASILY ATTACH YOUR HEADLIGHT OF CHOICE.
Screw in to light mount tab on Cruzbike front end for easy headlight installation.
