You may also like
S40 Rear Rack
Ships next business day
Beautiful, lightweight and strong - this sleek rear rack is custom-designed for the Cruzbike S40 endurance recumbent road bike and fits the panniers and trunk bags of your choice for fast commuting, randonneuring and touring setups.
The S40 Rear Rack is also quick and easy to install and ships with all hardware required to install on the Cruzbike S40.
Note: If you have a large trunk bag that you are planning on carrying on the rack top, you'll need to order extra-long rack arms, available for an additional $15.
PRODUCT DETAILS
- Weight: 2 lbs
VIDEO: S40 2021 Rear Rack Installation
LEGACY INSTALLATION VIDEO S40 2020 Rear Rack Installation Video
LEGACY INSTALLATION VIDEO S40 2019 Rear Rack Installation Video
LEGACY INSTALLATION GUIDE: S40 2020 Rear Rack
Cruzbike Under Seat Rack
Rugged Waterproof Pannier
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
Sling Pack
PRODUCT DETAILS
- Weight: 4.75 oz (132 g)
- Length: 15 inches (38 cm)
- Width: 2 inches (5 cm), up to about 4.5 inches (11 cm) when full
- Depth: 5 inches (13 cm)
Scarab Bag
LIGHTWEIGHT, WEATHER RESISTANT, HIGH VOLUME CARRY ALL DESIGNED FOR THE CRUZBIKE VENDETTA V20 AND S40.
This bag fits underneath the seat and wraps the frame for an ideal weight placement. The Scarab takes less than a minute to install. Easily fits your tools, a change of clothes plus a small laptop or your tablet for a commute or longer ride. Its placement does not distract from the aerodynamics and even when loaded does not affect the handling.
PRODUCT DETAILS
- Weight: 13.25 oz
- Length: 13 in (33 cm)
- Width: 12.5 in (31.75 cm)
- Depth: 7.5 in ( 19 cm) at deepest point
INSTALLATION GUIDE: Scarab Bag
VIDEO: Scarab Bag Installation
