You may also like
Cruzbike S40 2023 - Used/Returned
- All sales are final
- These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches and the bike will not be packed exactly as it would be new.
- We will support you to get the bike up and running with any spare parts you may need.
- The bike and parts will have our normal warranty.
- Ships worldwide
- Limited stock. When they're gone, they're gone.
- All S40 owner resources can be found here.
Cruzbike S40 2023 Recumbent Bike Tech Specs and Fit
Frame
Front Triangle
This patented drive system not only frees us from the long, inefficient chains and special parts fixed-boom recumbent bikes require, it links the upper and lower body across the drive train as it rotates around the axis of the head tube. This linkage allows Cruzbike recumbent bike riders to increase power when climbing or sprinting by engaging the upper body in much the same way professional cyclists do when they climb or sprint on traditional road bikes.
Fork
Racks and Bosses
S40 Complete Components
The 2023 S40 Complete is outfitted with a Microshift XLE 1x11 system we chose for performance and smooth shifting. The 42 tooth chainring with an 11x42 cassette hits the sweet spot for power on the flats and gearing for the climbs.
Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to make learning easier and improve handling) |
Shifter | Microshift XLE Right 11-Speed Lever for Cable Actuated Brakes |
Crankset | Driveline Crankset 165mm with 42T 110mm Narrow/Wide Chainring |
Bottom Bracket | Driveline 68mm English - External Bearing |
Cassette | Microshift G-Series 11-42T 11-Speed Cassette |
Chain | KMC X11-1 EPT Anti-Rust 1/2"x11/128" EPT |
Brakes | 160mm MCX-2 Mechanical Disc Brakes |
Wheels and Tires | 32 spoke 3 cross black aluminum rims, aero profile, tubeless compatible, 25 mm wide rim, approx 28 mm depth non-machined sidewalls, Maxxis Re-Fuse 700x32c tires |
Thru-Axles | The latest in high-end cycling axles attach the wheels more securely, are stiffer and flex less than their quick release predecessors, resulting in better power transfer and more resilience. For the new thru-axle on the S40 we chose a sleek, leverless style that even houses its own internal removal tool for the axle itself and brake rotors. |
Compatibility Notes
BB shell: English Thread 68mm
Brakes: Flat mount
Hydraulic disc brakes: The S40 2023 Frameset can be outfitted with hydraulic disc brakes using readily available long brake line kits. The exact proper length will be different for each bike/owner due to handlebar fit variations. Work with your local bike shop on this.
Weight
S40 Complete 2023: 28.6 lbs
Cruzbike S40 2023 Frameset - Warehouse Clearance
- These framesets have not been assembled. They have been shipped but should be in nearly new condition.
- Ships worldwide
Cruzbike S40 Recumbent Bike Tech Specs and Fit
Frame
Front Triangle
Fork
Racks and Bosses
Compatibility Notes
Brakes: Flat mount
Weight
Final weight of a custom-built Frameset will vary depending upon your component choice.
S40 Geometry
Wheelbase | 1130.3 mm | 44.5 in |
Chainstay length - standard | 450 mm | 17.75 in |
Rake (front fork offset) | 30 mm | 1.2 in |
Head tube angle (steering axis) | 71 degrees | |
Trail | 91.44 mm | 3.6 in |
Backrest angle | 40 degrees | |
Length of Bike (varies by adjustment and chainstay length) | ||
Seat Height (low point) | 609.6mm | 24 in |
BB Height (varies by adjustment) |
Fit
The S40 fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Check out the 2021 S40 Fit video here and head over to our Fit page for more great resources on fit.
Options
S40 FRAMESET: The S40 Frameset includes the frame, front triangle, optional front derailleur holder stalk, carbon fiber seat and cushion, headrest and cushion, custom-designed handlebar and grip tape. Work with your local bike mechanic to craft the perfect build. Instructions can downloaded from the S40 Owner's Resources on this page. The S40 Frameset ships worldwide.
Cruzbike V20c Frameset - Warehouse Clearance
This V20c Frameset is open box but otherwise brand new.
- Ships worldwide
- All V20c owner resources can be found here.
Cruzbike V20c Specs and Fit
Front Triangle
The new V20c boom utilizes a T47 85mm wide BB shell and an aero profile tube for the greatest blend of aerodynamics and stiffness possible. This shell capitalizes on stiffness where it matters most - right where your wattage is being generated.
This larger diameter shell is matched to the new chainstay, which is light, aero in profile and stiff laterally. It uses a broad new clamp design at the boom to maximize stiffness at the BB and chainstay interface.
The chainstay leads down to our new carbon fiber fork, which is light without being flimsy and utilizes an oversize tapered steerer with wider bearings for increased strength at the crown.
A 12mm through axle connects the wheel, fork, and stay together as a solid unit. The result is a strong and unparalleled power connection from the crank to the cassette with nearly zero deflection. The flat mount disc brakes are tucked in behind the blades for maximum aero. No other recumbent can claim a transmission with this little power loss, where deflections in booms, frames, and stays are all too common.
Tying the fork and boom together is our new slider, which uses a new internal connection as opposed to a boom clamp. The precisely designed pivot clamp is designed to spread the clamping forces on the slider tube and fork steerer without damage, slipping, or deflection under the types of torsional forces a Cruzbike front end can be subjected to. The fork portion of the pivot clamp replaces the headset top cap to reduce the number of pieces needed to set bearing tension.
All of these ingredients come together for the best power transfer possible with zero flex - while still feeling silky smooth. The ideal blend.
Add some clean internal cable routing in the fork for the front brake and derailleur, and in the boom/slider for the front derailleur and you have the cleanest, smoothest, most gorgeous Cruzbike front end to date.
Frame
The V20c headtube is now tapered with wider bearings to accommodate the new fork, and the geometry just slightly tweaked from its V20 predecessor for even smoother handling.
The main connection of the rear lower stays at the hydroformed tube now weld into a CNC machined yoke. The result is an increased torsional stiffness - an important thing on the twisty downhills especially for heavier riders - and has cleaned up the welds at that joint significantly while also being lighter.
The rear dropouts have been completely redesigned to accommodate a 12mm through axle which threads into a replaceable lightweight cap and accommodates standard flat mount disc brakes. They are CNC machined specifically to create the perfect blend of light weight, stiffness, and precision.
Compatibility Notes
BB shell: English Thread T47
Brakes: Flat Mount Disc Only
Weight
Main Frame: 1.6 kg ( 3.7lbs)
Complete: Complete weight varies depending upon component choice.
Vendetta V20c Geometry
Wheelbase | 1149 mm | 45.3 in |
Chainstay length - standard | 496.9mm | 19.6 in |
Backrest angle | 20 degrees | |
Length of Bike (varies by adjustment and chainstay length) | 1803 - 2032 mm | 71 - 80 in |
Seat Height (low point) | 521.2mm | 20.5 in |
BB Height (varies by adjustment and chainstay length) | 584 - 846mm | 23 - 34 in |
Fit
The V20c fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). This article includes a helpful fitment chart. Check out our blog post on how to measure x-seam here. If you are at either end of the fit range and have questions, contact us at hello@cruzbike.com. We'd love to get you fit.
Cruzbike Q45 2022 - Used/Returned
Ships next business day
The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride.The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
- Ships worldwide
- All Q45 owner resources can be found here.
Cruzbike Q45 2022 Tech Specs and Fit
Frame
Front Triangle
Suspension System
Adjustable Seat
Racks and Bosses
Dual 650b Wheels and Thru-Axles
Custom-designed Handlebar
Q45 Recumbent Touring Bike Components
Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.) |
Shifter | Microshift XLE 1x11 Trigger (MTB) |
Derailleur | Microshift RD-M665M 11-speed |
Chain Wheel | Driveline 155 42T with black anodized chain guard |
Cranks | Driveline DX-42 155 |
Bottom Bracket | Square Taper 68mm*113mm |
Cassette | Microshift 11-42T |
Chain | YBN 114 links - just one standard chain length |
Brakes | Jagwire MC-X Mechanical Disc |
Rear Shock | KS EXA Form 290 165 mm with external spring rated at 1200 lbs/inch |
Wheels and Tires | 650b Jet Set rims, Chosen hubs, with Maxxis Overdrive 650b x 1.65 inch tires |
Compatibility Notes
Weight
Q45 Complete: 33 lbs
Q45 Geometry
Wheelbase | 114 cm | 45.0 in |
Chainstay Length | 44.8 cm | 17.638 in |
Backrest angle | ||
Length of Bike (varies by adjustment and chainstay length) | 179 cm | 70.5 in |
Seat Height (measured at the low point of the seat pan, not including the cushion.) | 63.5 cm | 25 in |
BB Height (varies by adjustment and chainstay length) | 68.58 cm | 27 in |
Recumbent Touring Bike Fit
The Q45 fits riders with an X-seam between approximately 34" and 47" (approximately 5'1" to 6'4"). Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
Options
Q45 COMPLETE: The Q45 complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours.
Cruzbike T50 2022 Complete - Used/Returned
This limited inventory of used/returned stock is your opportunity to get rolling on a T50 for an incredible price.
- These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches.
- Ships worldwide
- All T50 owner resources can be found here.
Cruzbike T50 2022 Tech Specs and Fit
Frame
Front Triangle
Adjustable Seat
PLUS the 2022 T50 features the new fiber/resin seat introduced on the latest Cruzbike Q45 adventure touring bike. It delivers a fantastic compliant road feel, is half a pound lighter and one and a half inches taller than its aluminum predecessor. Pair it with Cruzbike's one piece seat cushion that cradles riders from shoulders to derrier and yep, our favorite cruiser just got even more comfortable.
T50 Complete Components
Shifter | Microshift Bar End BS-A09 9 speed |
Chain Wheel | Jason 38T with bash guard |
Cassette | Sunrace M96 11-32 |
Rear derailleur | Shimano Sora 9 Speed |
Chain | YBN 9 speed - 120 Link |
Brakes | Mechanical Disc Rever MCX02 OR Avid BB5 Caliper and Tektro CL-530 Levers |
Wheels and tires | 26"*32H Double Wall Alloy rims, Duro 26x1.5" tires |
Compatibility
Braze-on derailleur: There is no mount point for a braze-on derailleur. A clamp on derailleur on the boom tube will work.
Tire clearance: 2" tire maximum without fenders, 1.75" tire maximum with fenders.
Cruzbike T50 Geometry
Wheelbase: Throw this bike on standard racks, easily. Whether you're taking a bus, parking at a coffee shop or heading somewhere by car, the T50 is easy to bring along. |
109 cm |
43 in |
Backrest angle: Dial in the perfect seat back angle with simple adjustments. |
53 - 76 degrees |
Handlebar height: |
Adjustable |
Seat Height (low point): Feel great whether pedaling or stopped at an intersection with your feet on the ground. |
55.9 cm |
22 in |
Weight
T50 Complete: 30 lbs. T50s built from T50 Framesets will vary with component choice.
Fit
Options
T50 COMPLETE: The T50 complete ships with components pre-installed. Plan for 2-3 hours for assembly if you are a novice. Experienced mechanics will be able to complete the assembly in about 30 minutes. Ships worldwide.
T50 FRAMESET: The essential building blocks to build (or have your local bike shop build) your next favorite bike. The T50 Frameset includes frame, front triangle, riser, stem, handlebar and seat assembly and cushion. Source your own components and have a mechanic build your T50. Ships worldwide.
To complete your build you will need: Shifters, Cassette, Chain, Rear Derailleur, Crankset and Bottom Bracket, Pedals, Disc Brakes with Rotors, Grips, Brake Levers, 26" Wheels, Tubes, Tires, Brake Cables (Rear is a long length), Cable Housing.
