Cruzbike Q45 2022 - Used/Returned
Regular price $3,400.00 Sale price $2,500.00
In Stock
Ships next business day
Out Stock
The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride.The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
  • All sales are final
  • These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches and the bike will not be packed exactly as it would be new.
  • We will support you to get the bike up and running with any spare parts you may need.
  • The bike and parts will have our normal warranty.
  • Ships worldwide
  • Limited stock. When they're gone, they're gone.
  • All Q45 owner resources can be found here.
Cruzbike Q45 2022 Tech Specs and Fit
Frame
Unique swing arm design allows the Q45's robust aluminum frame to run a super smooth suspension system and pack down for travel.
    Front Triangle
    Cruzbike's patented race-proven dynamic boom drivetrain is the engine of the Q45 recumbent touring bike. The same system that powers our performance bikes to records and wins powers the Q45 so you'll be able to take on whatever mountain range is on your bucket list, while hauling all your gear.
      Suspension System
      The Q45 boasts a full-size (165 mm) external coil shock that rides super smoothly, accommodating a heavily-loaded bike and blowing open the terrain upon which the Q45 thrives. Mixed surfaces on that trip you're dreaming of doing? No problem.
        Adjustable Seat
        The 2022 Q45 features a new resin seat that has a great compliant feel on the road, making this Q45 the most comfortable yet and it is half a pound lighter than its aluminum predecessor. It is ergonomically designed for comfort for riders of all shapes and sizes. The cushion is a one-piece dream that cradles its rider from shoulders to derriere. The seat back angle is also adjustable so you can get your backrest dialed in just the way you like it.
          Racks and Bosses
          The Q45 is designed for hauling gear and mounting accessories. It boasts 8 threaded mount points on each side and one in the middle under the down tube plus a dedicated fender mount. Load up panniers, mount lights, install fenders - anything you need for your adventure - this bike can handle it.
            Dual 650b Wheels and Thru-Axles
            We are the first recumbent bicycle company to offer dual 650b wheels and thru-axles. Thru-axles improve stiffness in the drivetrain, handling, cornering, and power transfer. We made these massive upgrades to the Q45’s spec to deliver even better performance and an even smoother ride. 650b wheels open up options to customize your Q45 with a huge variety of performance wheels and tires.This bike ships with 1.65 inch tires we chose for performance (even in wet weather), durability and value. And you'll still have plenty of space for fenders.
              Custom-designed Handlebar
              The awesome custom-designed Q45 handlebar features road styling but is sized for mountain shifters and levers. This opens a whole world of component options and also creates more space in the cockpit for better rider fit.
                Q45 Recumbent Touring Bike Components
                Headset Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.)
                Shifter Microshift XLE 1x11 Trigger (MTB)
                Derailleur Microshift RD-M665M 11-speed
                Chain Wheel Driveline 155 42T with black anodized chain guard
                Cranks Driveline DX-42 155
                Bottom Bracket Square Taper 68mm*113mm
                Cassette Microshift 11-42T
                Chain YBN 114 links - just one standard chain length
                Brakes Jagwire MC-X Mechanical Disc
                Rear Shock KS EXA Form 290 165 mm with external spring rated at 1200 lbs/inch
                Wheels and Tires 650b Jet Set rims, Chosen hubs, with Maxxis Overdrive 650b x 1.65 inch tires
                Compatibility Notes
                Maximum cassette width: The Q45 can accommodate up to 11-42 cassette with its 1x chainring. Learn more about the Q45's gearing here.
                Maximum tire sizeWith the stock 1.65 inch 650b tires, you'll have 12 mm of clearance. Different tire choices will yield different clearances.
                Weight
                Q45 Complete: 33 lbs
                Q45 Geometry
                Wheelbase 114 cm 45.0 in
                Chainstay Length 44.8 cm 17.638 in
                Backrest angle
                Length of Bike (varies by adjustment and chainstay length) 179 cm 70.5 in
                Seat Height (measured at the low point of the seat pan, not including the cushion.) 63.5 cm 25 in
                BB Height (varies by adjustment and chainstay length) 68.58 cm 27 in
                Recumbent Touring Bike Fit
                The Q45 fits riders with an X-seam between approximately 34" and 47" (approximately 5'1" to 6'4"). Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
                Options
                Q45 COMPLETE: The Q45 complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours.
