Cruzbike Q45 - Used/Returned
The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride.The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
The Q45 Complete in stone includes a Q Touring and Commuting Rear Rack and Mirror
- All sales are final
- These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches.
- We will support you to get the bike up and running with any spare parts you may need.
- The bike and parts will have our normal warranty.
- Ships worldwide
- Limited stock. When they're gone, they're gone.
- All Q45 owner resources can be found here.
Cruzbike Q45 Tech Specs and Fit
Frame
Front Triangle
Suspension System
Adjustable Seat
Racks and Bosses
Q45 Complete Components
We chose 1x11 MTB components that balance performance, durability and value. This setup is designed to thrive even with a fully loaded Q45. Choosing gearing is an art and a science. Learn more about the Q45 2019's gearing here.
Shifter | SRAM NX 11-speed X-ACTUATION Grip Shift |
Chain Wheel | Driveline DX-38AG 38T*155mm with bash guard |
Bottom Bracket | Square Taper 68mm*113mm |
Cassette | SRAM PowerGlide 11-42T 11-Speed Cassette |
Chain | SRAM PC-1130 11-Speed (114 links - just one standard chain length) |
Brakes | SRAM Mechanical Disc |
Wheels and Tires | Jetset 26"*32H Double Wall Alloy rims, Maxxis Overdrive Excel 26x1.75" tires |
Compatibility Notes
Hub spacing: The front fork is compatible with standard 130 mm or 135 mm hubs. The rear dropout is compatible with standard 100 mm hubs.
Maximum tire size: The Q45 ships with 1.75" tires but can accommodate up to 2" tires.
Weight
Q45 Complete: 15.4 kg ( 34 lbs). Final weight may vary depending upon component choice. Note that the stock wheels (with tires, tubes, etc.) weigh nearly 9 lbs, so there are ripe opportunities for weight weenies to lighten up.
Q45 Geometry
Wheelbase | 113 cm | 44.5 in |
Chainstay length - standard | 44.8 cm | 17.638 in |
Backrest angle | 30-53 degrees | |
Length of Bike (varies by adjustment and chainstay length) | 179 cm | 70.5 in |
Seat Height | 63.5 cm | 25 in |
BB Height (varies by adjustment and chainstay length) | 68.58 cm | 27 in |
Fit
The Q45 fits riders with an X-seam between 34" and 46" (approximately 5'1" to 6'3"). The cockpit of the Q45 is a little tighter than the T50 or the S40, so if you are taller than 6'3" or weigh more than 200 lbs, it may not work for you. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
