Cruzbike S40 2021 Frameset - Warehouse Clearance
Ships next business day
- All sales are final
- These framesets are brand new past season stock.
- The bike and parts will have our normal warranty.
- Ships worldwide
- Limited stock. When they're gone, they're gone.
- All S40 owner resources can be found here.
Cruzbike S40 2021 Recumbent Bike Tech Specs and Fit
Frame
Front Triangle
This patented drive system not only frees us from the long, inefficient chains and special parts fixed-boom recumbent bikes require, it links the upper and lower body across the drive train as it rotates around the axis of the head tube. This linkage allows Cruzbike recumbent bike riders to increase power when climbing or sprinting by engaging the upper body in much the same way professional cyclists do when they climb or sprint on traditional road bikes.
Fork
Racks and Bosses
Compatibility Notes
BB shell: English Thread 68mm
Brakes: Flat mount
Hydraulic disc brakes: The S40 2021 Frameset can be outfitted with hydraulic disc brakes using readily available long brake line kits. The exact proper length will be different for each bike/owner due to handlebar fit variations. Work with your local bike shop on this.
S40 Geometry
Wheelbase | 1130.3 mm | 44.5 in |
Chainstay length - standard | 450 mm | 17.75 in |
Rake (front fork offset) | 30 mm | 1.2 in |
Head tube angle (steering axis) | 71 degrees | |
Trail | 91.44 mm | 3.6 in |
Backrest angle | 40 degrees | |
Length of Bike (varies by adjustment and chainstay length) | ||
Seat Height (low point) | 609.6mm | 24 in |
BB Height (varies by adjustment) |
Fit
The S40 fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Check out the 2021 S40 Fit video here and head over to our Fit page for more great resources on fit.
Options
S40 FRAMESET: The S40 Frameset includes the frame, front triangle, optional front derailleur holder stalk, carbon fiber seat and cushion, headrest and cushion, custom-designed handlebar and grip tape. Work with your local bike mechanic to craft the perfect build. Instructions can downloaded from the S40 Owner's Resources on this page. The S40 Frameset ships worldwide.
