Deep Rims
Discussion in 'Vendetta Series (V1.x, V2.x, V20)' started by DavidCH, Mar 4, 2016.
  1. ratz
    ratz Wielder of the Rubber Mallet
    Pretty much only Silca makes the long ones; everyone else you have to use the extensions; which works well enough once you get them installed tightly.
  2. DavidCH
    DavidCH In thought; expanding the paradigm of traversity
  3. ratz
    Does it include a pump or does it attach to a pump?
  4. bazzawill
    bazzawill Active Member
  5. bazzawill
    Actually the 100mm silca comes as a 50mm plus extender which works fine
  6. bazzawill
    Attaches to a pump
  7. RojoRacing
    RojoRacing Donut Powered Wise-guy
    80mm are one piece
  8. trplay
    trplay Zen MBB Master
    Good luck tomorrow Jason!
  9. DavidCH
    15 minutes has got to be a record to get a tubeless tyre inflated.
    This 23mm Schwalbe pro one tubeless looks big! Can't wait to try it tomorrow.
  10. DavidCH
    Attaches to a pump
  11. ccf
    ccf Well-Known Member
    Did you every have any correspondence with them? I've sent them a message via their website plus two emails with no reply.
    -Cliff
  12. ccf
    @RojoRacing, have you run tubeless on your Acebike wheels? If yes, how did it or has it worked out?
    -Cliff
  13. bazzawill
    I run tubeless on 88mm acebike wheels they are great Rojo also runs tubeless as he helped me with a few things. I use standard Gaffa tape to seal the rim due to Rojos assistance. I was having trouble with the expensive silca tape I was trying, although that trouble may be due to a hole I later found in the sidewall of my 28mm schwalbe pro one.
    It is a little different to the tubeless (read sealed) rims I was using from DT Swiss but it does the job and means I could afford to upgrade to deep CF from alloy. I can only dream of DT Swiss rims but at least I have their hubs.
  14. ccf
    I'm thinking I'd like to copy Rojo's choice of wheels since I need disc brakes for the hilly terrain and I really want to try tubeless (6 flats last week) and I may as well get aero wheels if I'm going to change them. But the DTSwiss hubs that support disc brakes are 142*12 and @Robert Holler says that the frame is designed for 130 and can stretch to 135. So how did @RojoRacing (or anyone else who has fit DTSwiss disc brake compatible hubs to the frame) get them to fit?
    -Cliff
  15. RojoRacing
    I suggest getting the 240s hubs vs the 350s hubs I had to choose because the 240s was out of stock. The 240s has a better non drive wheel end cap option to work on our bike which will save you like 50 grams. The drive wheel will come setup for 142/12 but can be converted to 135 with accessory end caps. Click this link and then the accessories tab to look at the options
    https://www.dtswiss.com/Components/Hubs-Road/350-straightpull-db-RW
  16. ccf
    Thanks for the help. Which size end cap fits the Cruzbike frame best?
  17. ratz
    For Disc Brakes on the V20/S30 you need reversed road standard so....
    100mm for the back wheel
    135mm for the front wheel
    Fronts will all be 100mm that's pretty standard.
    For the rear....
    5/135 MM QR REAR
    Part. No.: HWGXXX0001528S
    Convert this product into 5 mm QR
  18. RojoRacing
    240 hubs may come with everything you need to fit the cruzbike. The 350 hubs will come with the needed part for the drive wheel but not the non drive wheel. The part needed for the non drive wheel can be a little tricky to find but it's out there via third party.
  19. ccf
    Is it this one for the non-drive wheel:
    5/100 MM FIFTEEN / TRICON QR FRONT
    Part. No.: HWGXXX0002328S
    Convert this product into 5mm QR
  20. bazzawill
    240s do not come with either part
    You need HWGXXX0002328S and HWGXXX0001528S
Share This Page
