You may also like
Touring and Commuting Rack
Ships in 1-2 business days
Transform your A4x or Q into the ultimate commuter or touring bike. Made sturdy for fully-loaded panniers and trunk bags this rack is as robust as it is good looking. It is compatible with trunk bags, baskets, and panniers.Â
PRODUCT DETAILS
- Weight: 2.3 lbs (1.04 kg)
- Length:Â 25 in (63.5 cm)
- Width at Top: 5 in (12.7 cm)
- Width at Bottom: 10 in (25.4 cm)
- Expected Max Load Range: 25-30 lbs range when that weight is evenly distributed in two bags, one on each side. If using only one side of the rack it is best to stick to 10 lbs or less.
VIDEO A4x Installation:Â Touring and Commuting Rack Installation.
Rugged Waterproof Pannier
We've found the ultimate pannier for recumbent road bikes. This rugged bag packs all of our must-haves into one perfectly-dimensioned package. It is completely water proof, easy to securely attach and detach with its universal adjustable rail, features reflective tape for visibility and boasts 15L of storage and a shoulder strap for off-bike carrying. It's perfectly dimensioned for hauling gear under your Cruzbike recumbent bicycle seat on the Under Seat Racks.
Video: Waterproof Pannier AdjustmentÂ
Product Details:
Volume: 15L (per pannier)
KLICKFix Universal Rail Adjustable rail with flexible handle for all carrier sizes. The UNIVERSAL rail comes with adjustable standard hooks that fit for Ă 8/10/12mm.Â
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
Ventisit Seat Cushion
The Ventisit recumbent bicycle seat pad has an open structure with a layer of air between you and the seat, nearly eliminating a sweaty back. It provides noticeable suspension, but itâs not too soft. The material does not absorb moisture and you only need to shake it after a rain shower. It is shaped to ďŹt the unique Cruzbike seat. It is one of our favorite recumbent road bike accessories.
Cygolite Dash 520 Head Light
LIGHT THE ROAD AHEAD.
Powerful 520 lumen head light great for Cruzbike recumbent bicycles. 24/7 Safety TechnologyÂŽ gives you a powerful selection of 8 night and day modes: Boost, High, Medium, Low, SteadyPulseÂŽ, QuadDRL Steady, Quad DRL Flashing and DayLightningÂŽ
- Low-profile, water-resistant design
- Weight:Â 79g
- USB-rechargeable internal battery
INSTALLATION NOTE:Â You will need the Mount Light Stub for installation.
Cruzbike Bottle Cage
Light weight, anodized alloy side and top-pull cage that works for either left or right. Includes required installation hardware.Â
Â
PRODUCT DETAILS:
Weight: 47 grams
