You may also like
Q Touring and Commuting Rack
Ships next business day
Transform your Q into the ultimate commuter or touring bike with Cruzbike's rack specially designed for the Q. Made sturdy for fully-loaded panniers and trunk bags this rack is as robust as it is good looking. It is compatible with trunk bags, baskets, and panniers.
PRODUCT DETAILS
- Weight: 2.3 lbs (1.04 kg)
- Length: 25 in (63.5 cm)
- Width at Top: 5 in (12.7 cm)
- Width at Bottom: 10 in (25.4 cm)
- Expected Max Load Range: 25-30 lbs range when that weight is evenly distributed in two bags, one on each side. If using only one side of the rack it is best to stick to 10 lbs or less.
VIDEO Q45 Installation: Q Touring and Commuting Rack Installation.
Rugged Waterproof Pannier
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
Ventisit Seat Cushion
Cygolite Dash 520 Head Light
LIGHT THE ROAD AHEAD.
Powerful 520 lumen head light great for Cruzbike recumbent bicycles. 24/7 Safety Technology® gives you a powerful selection of 8 night and day modes: Boost, High, Medium, Low, SteadyPulse®, QuadDRL Steady, Quad DRL Flashing and DayLightning®
- Low-profile, water-resistant design
- Weight: 79g
- USB-rechargeable internal battery
INSTALLATION NOTE: You will need the Mount Light Stub for installation.
Cruzbike Bottle Cage
PRODUCT DETAILS:
Weight: 47 grams
