You may also like
Race Cage
Optional divider weight: 120g
Dimensions:
Length: 14 inch
Width: 11 tapering to 5 inch
Volume: 12L
Adjustable Carbon Fiber Seat and Headrest
Fit and Specifications:
| Max Width at Shoulders: | 22.9 cm (9 in) |
| Max Width at Seat: | 26 cm (10.25 in) |
| Min Width: | 19.4 cm (7.625 in) |
| Max Adjustable Length: | 80 cm (31.5 in) |
| Min Adjustable Length: | 63.5 cm (25 in) |
- Two-Piece Adjustable Carbon Fiber Seat
- All Required Mounting Hardware
- Ventisit Seat Cushion
- Headrest and Cushion
Installation Resources:
Vendetta V20c Recumbent Bicycle Racing Jersey
Ships in 1-2 business days
