You may also like
Touring and Commuting Rack
Ships in 1-2 business days
PRODUCT DETAILS
- Weight: 2.3 lbs (1.04 kg)
- Length: 25 in (63.5 cm)
- Width at Top: 5 in (12.7 cm)
- Width at Bottom: 10 in (25.4 cm)
- Expected Max Load Range: 25-30 lbs range when that weight is evenly distributed in two bags, one on each side. If using only one side of the rack it is best to stick to 10 lbs or less.
Cruzbike Under Seat Rack
Rugged Waterproof Pannier
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
Cruzbike Trunk Bag
Features include:
- Expandable side panels for additional storage capacity
- Easy attach and release access, with integrated anti-theft latch
- Unique KlickFix UniKlip adapter for easy mounting to rear rack
- Water-resistant polyester fabric, plus an additional bag rain cover
- Reflective Cruzbike wordmark and logos
Weight: 4.6 lbs / 2.1 kg
Dimensions:
Main Bag
Width: 15.75 in / 40 cm
Height: 10.4 in / 26.5 cm
Depth: 7.7 in / 19.5 cm
Volume: 20 L
Side Pocket (per side)
Width: 11 in / 28 cm
Height: 14.6 in / 37 cm
Depth: 1.4 in / 3.5 cm
Volume: 2.5 L
