You may also like
Axiom Journey Rack
Ships next business day
STURDY, EASY TO INSTALL REAR RACK FOR HAULING.
Transform your T50 into the ultimate utility machine with the Axiom Journey rear rack. We love this rack for its ease of use, durability and strength.
INSTALLATION GUIDE: Axiom Journey and Portland Design Works Payload Racks
Rugged Waterproof Pannier
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
T50 and Q45 Kickstand
LIGHTWEIGHT KICKSTAND CUSTOM-DESIGNED FOR CRUZBIKE RECUMBENT BIKES.
This lightweight, extra-long kickstand is designed for the Cruzbike T50 and Q45. It is compatible with all Cruzbike T50s (select year option) and can also be used to replace the stock Q45 kickstand.
INSTALLATION GUIDE: T50 Kickstand
B&M CycleStar Mirror
RIDE SAFELY WITH A REAR VIEW.
- Weight: 58 grams / 2 ounces.
Ventisit
