You may also like
Racktime T50 Rear Rack
STURDY, EASY TO INSTALL REAR RACK FOR HAULING.
Transform your T50 into the ultimate utility machine with the Racktime Basic 2.0 Tour Rear Rack. We love this rack for its ease of use, durability and strength.
This rack is compatible with our selection of panniers and all standard panniers and is SNAPIT 2.0 compatible, with spring clamp and mounting plate for a rear light.
Maximum load: 25 kg | 55 lbs.
Tube diameter: 14 mm | 0.55 in
Everyday Pannier
Product Details:
Volume: 14 L
Weight: 1 kg
Quick release system
Dimensions:
Width 34 cm
Depth 13.5 cm
Height 32 cm
Rugged Waterproof Pannier
Ships in 1-2 business days
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
B&M CycleStar Mirror
RIDE SAFELY WITH A REAR VIEW.
- Weight: 58 grams / 2 ounces.
T50 and Q45 Kickstand
LIGHTWEIGHT KICKSTAND CUSTOM-DESIGNED FOR CRUZBIKE RECUMBENT BIKES.
This lightweight, extra-long kickstand is designed for the Cruzbike T50 and Q45. It is compatible with all Cruzbike T50s (select year option) and can also be used to replace the stock Q45 kickstand.
INSTALLATION GUIDE: T50 Kickstand
