![Wide Sweep Mountain Handlebar](http://cruzbike.com/cdn/shop/products/q45-2021-handlebar-accessories-900x900_{width}x.jpg?v=1613408962)
Regular price
$50.00
In Stock
Ships next business day
Out Stock
Custom-designed wide sweep mountain handlebar for the Q45.
26” wide at the grip end and standard 22.2mm size for MTB shifters/levers, and 31.8mm clamp size.
Grip section can be cut for custom length.
Compatibility: These will work on all Q45s as a direct swap (with some re-cabling). They will also work on the S40 if you want to build your S40 up with MTB shifters and levers. Road shifters and levers are not compatible with this bar.
VIDEO: Wide Sweep Mountain Handlebar Swap on Q45
