You may also like
S40 Rear Rack
Ships in 1-2 business days
Beautiful, lightweight and strong - this sleek rear rack is custom-designed for the Cruzbike S40 endurance recumbent road bike and fits the panniers and trunk bags of your choice for fast commuting, randonneuring and touring setups.
The S40 Rear Rack is also quick and easy to install and ships with all hardware required to install on the Cruzbike S40.
PRODUCT DETAILS
- Weight: 2 lbs
VIDEO: S40 2021 Rear Rack Installation
LEGACY INSTALLATION VIDEO S40 2020 Rear Rack Installation Video
LEGACY INSTALLATION VIDEO S40 2019 Rear Rack Installation Video
LEGACY INSTALLATION GUIDE: S40 2020 Rear Rack
Cruzbike Under Seat Rack
Race Cage
Transport: The race cage should be removed from your bike when transporting it on a car rack. Bouncing motion at high speeds can weaken the cantilevered frame and will void the warranty.
Optional divider weight: 120g
Dimensions:
Length: 14 inch
Width: 11 tapering to 5 inch
Volume: 12L
Rugged Waterproof Pannier
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
Sling Pack
PRODUCT DETAILS
- Weight: 4.75 oz (132 g)
- Length: 15 inches (38 cm)
- Width: 2 inches (5 cm), up to about 4.5 inches (11 cm) when full
- Depth: 5 inches (13 cm)
