Ships next business day
MOUNT YOUR REAR LIGHT, CAMERA, OR OTHER LIGHTWEIGHT ACCESSORIES.
The Cruzbike Utility Post is an add-on product for the Headrest Cage Mount Kit. It adds a standard seat tube diameter space to mount your rear light, camera, or other lightweight accessories. The mounting tabs are standard bottle cage spacing.
PRODUCT DETAILS
Weight: 3.5 oz
Height: 15 cm
Compatibility: All V series models, S40, Silvio, S30 - requires Headrest Cage Mount Kit to be mounted to the rear headrest.
INSTALLATION GUIDE: Headrest Cage Mount Kit and Utility Post Add-on
Beautiful, lightweight and strong - this sleek rear rack is custom-designed for the Cruzbike S40 endurance recumbent road bike and fits the panniers and trunk bags of your choice for fast commuting, randonneuring and touring setups.
The S40 Rear Rack is also quick and easy to install and ships with all hardware required to install on the Cruzbike S40.
Note: If you have a large trunk bag that you are planning on carrying on the rack top, you'll need to order extra-long rack arms, available for an additional $15.
PRODUCT DETAILS
VIDEO: S40 2021 Rear Rack Installation
LEGACY INSTALLATION VIDEO S40 2020 Rear Rack Installation Video
LEGACY INSTALLATION VIDEO S40 2019 Rear Rack Installation Video
LEGACY INSTALLATION GUIDE: S40 2020 Rear Rack
Product Details:
Volume: 15L (per pannier)
High frequency welded seems
Reflective accents
Dimensions:
Width: 34 cm
Depth: 19 cm
Height: 34 cm
Weight: 1.2 kg
PRODUCT DETAILS
LIGHTWEIGHT, WEATHER RESISTANT, HIGH VOLUME CARRY ALL DESIGNED FOR THE CRUZBIKE VENDETTA V20 AND S40.
This bag fits underneath the seat and wraps the frame for an ideal weight placement. The Scarab takes less than a minute to install. Easily fits your tools, a change of clothes plus a small laptop or your tablet for a commute or longer ride. Its placement does not distract from the aerodynamics and even when loaded does not affect the handling.
PRODUCT DETAILS
INSTALLATION GUIDE: Scarab Bag
VIDEO: Scarab Bag Installation
