Ships in 1-2 business days
If you want maximal power when climbing or sprinting, there is no crank length better than 145mm. Read this blog post for the technical explanation.
This 145mm Short Crank upgrade kit comes with 145mm crank arm set, 38T 1x Chainring, Bottom Bracket and 24mm Axle.
Bring this to your local bike shop for professional installation. Installation requires specialized tools and experience. Mechanics notes can be found here.
The T47 BB is compatible with our Cruzbike Vendetta V20c (Gen 1 and Gen 2).
The BSA BB is compatible with all other Cruzbike models.
Component Weights:
Transport: The race cage should be removed from your bike when transporting it on a car rack. Bouncing motion at high speeds can weaken the cantilevered frame and will void the warranty.
Optional divider weight: 120g
Dimensions:
Length: 14 inch
Width: 11 tapering to 5 inch
Volume: 12L
| Max Width at Shoulders: | 22.9 cm (9 in) |
| Max Width at Seat: | 26 cm (10.25 in) |
| Min Width: | 19.4 cm (7.625 in) |
| Max Adjustable Length: | 80 cm (31.5 in) |
| Min Adjustable Length: | 63.5 cm (25 in) |
The team at BendIt Cycling designed this awesome jersey color matched to each of the Cruzbike V20c original colorways (Race Red, Vendetta Gold and Classic White). The fastest recumbent bike now has a sweet jersey to go with it.
MOUNT YOUR REAR LIGHT, CAMERA, OR OTHER LIGHTWEIGHT ACCESSORIES.
The Cruzbike Utility Post is an add-on product for the Headrest Cage Mount Kit or the Race Cage. It adds a standard seat tube diameter post that allows you to mount your rear light, camera, or other lightweight accessories onto the headrest cage mount or the back of the race cage. The mounting tabs are standard bottle cage spacing. Note: the Utility Post for the Race Cage has higher price due to additional hardware included for mounting.
PRODUCT DETAILS
Weight: 3.5 oz
Height: 15 cm
Compatibility: All V series models, S40, Silvio, S30 - requires Headrest Cage Mount Kit to be mounted to the rear headrest.
INSTALLATION GUIDE: Headrest Cage Mount Kit and Utility Post Add-on
