Dial in the perfect fit for the fastest recumbent road bike ever with the Carbon Fiber Curved Slider. This curved slider is designed to lower the handlebars for better visibility, or to raise the handlebars for more clearance by 40mm up or down. This slider also features bottle cage mounts, just like the stock slider.
Note: This carbon fiber curved slider is only compatible with the Cruzbike Vendetta V20c. Our aluminum Curved Slider is compatible with S40 and older V20 models.
The V20c is NOW SHIPPING. Speed fiends rejoice.
Click here for full details on the My Fastest Bike Guarantee program.
Ships next business day
The Cruzbike Q45 adventure touring recumbent bicycle is built to take you and your gear wherever you want to go, as far as you want to ride.
The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
NOW SHIPPING
Max Width at Shoulders: | 22.9 cm (9 in) |
Max Width at Seat: | 26 cm (10.25 in) |
Min Width: | 19.4 cm (7.625 in) |
Max Adjustable Length: | 80 cm (31.5 in) |
Min Adjustable Length: | 63.5 cm (25 in) |
Includes headrest, mounting hardware and velcro. Does not include seat pad.
