You may also like
V20c Complete Gen 2
Ships in 1-2 business days
Click here for full details on the My Fastest Bike Guarantee program.
- To learn more about the Complete and Frameset options, click here.
- Fit: The V20c fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Check out our blog post on how to measure x-seam here. If you are at either end of the fit range and have questions, contact us at hello@cruzbike.com. We'd love to get you fit.
S40 Complete Gen 6
- The Gen 6 S40 ships with the Suspension Adjustable Headrest included in the box
- Fit: The S40 fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Head over here to learn more about fit. If you are at either end of the fit range and have questions, contact us at hello@cruzbike.com. We'd love to get you fit.
V20c Frameset Gen 2
A4x Complete Gen 1
The A4x Complete adventure touring recumbent bike ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours for assembly. We also recommend a professional pre-ride tune-up if you don't work on bikes regularly. The A4x Complete ships worldwide
Cruzbike A4x Adventure Touring Recumbent Bike Key Features:
- Dynamic Boom Front Wheel Drive — Cruzbike's patented, race-proven drivetrain engages upper and lower body for powerful climbing and efficient cruising, even under a full touring load
- Dual-position, tunable suspension — DNM Torch DV-22 165 mm with external spring rated at 1500 lbs/inch, with dual-position mount for progressive or linear ride character and adjustable spring preload for load and rider weight tuning
- Rearward suspension pivot — pivot sits behind the rider rather than underfoot, eliminating the vertical bounce of earlier designs for true off-pavement composure and confident tracking through technical terrain
- Croder SPIRIT modular crankset — lightweight, precision-engineered crank system with interchangeable arm lengths, spiders, and chainrings available directly through Croder; stock spec: 155mm arm, 24mm axle, DM42T chainring (6mm offset), BSA24 steel bearing bottom bracket
- Adjustable seatback angle — dial in your riding position between 44 and 77 degrees for the terrain ahead on the A4x's compliant, comfortable resin seat.
- Adventure-ready rack and bag compatibility — extensive mounting options for panniers, frame bags, handlebar bags, and more; configure your carry system for any mission
- Robust kickstand mount and stock single kickstand — the beefy and adjustable kickstand that comes stock with the A4x Complete will work for the 650b stock wheels and 24” conversion. This is really good for parking a fully-loaded bike when you pull off for a coffee. Plus, this mount is also compatible with a double kickstand for those who prefer that setup.
- Purpose-built off-pavement frame — new heavy-duty chassis engineered for trail, gravel, and mixed-surface touring with the structural integrity to handle loaded adventure riding
- Recumbent ergonomics — full-body comfort eliminates the wrist, neck, shoulder, and saddle pain that ends adventures early on traditional bikes
- Generous tire clearance — stock 650b wheels accommodate tires up to 57mm (2.25") wide; swap to 24" wheels and clearance opens up to 68mm (2.6") for even more capable rubber on demanding terrain. Note: fender installation is not compatible at maximum tire width.
- Packable for air travel —disassembles to fit inside the Tern Airporter Slim hard-shell case (with 24" wheels) at standard checked luggage dimensions, making international and fly-to-ride adventures genuinely practical
Cruzbike Q45
The Cruzbike Q45 adventure touring recumbent bicycle is built to take you and your gear wherever you want to go, as far as you want to ride.
The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
