The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride.The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
Frame
Unique swing arm design allows the Q45's robust aluminum frame to run a super smooth suspension system and pack down for travel.
Front Triangle
Cruzbike's patented race-proven dynamic boom drivetrain is the engine of the Q45 recumbent touring bike. The same system that powers our performance bikes to records and wins powers the Q45 so you'll be able to take on whatever mountain range is on your bucket list, while hauling all your gear.
Suspension System
The Q45 boasts a full-size (165 mm) external coil shock that rides super smoothly, accommodating a heavily-loaded bike and blowing open the terrain upon which the Q45 thrives. Mixed surfaces on that trip you're dreaming of doing? No problem.
Adjustable Seat
The 2022 Q45 features a new resin seat that has a great compliant feel on the road, making this Q45 the most comfortable yet and it is half a pound lighter than its aluminum predecessor. It is ergonomically designed for comfort for riders of all shapes and sizes. The cushion is a one-piece dream that cradles its rider from shoulders to derriere. The seat back angle is also adjustable so you can get your backrest dialed in just the way you like it.
Racks and Bosses
The Q45 is designed for hauling gear and mounting accessories. It boasts 8 threaded mount points on each side and one in the middle under the down tube plus a dedicated fender mount. Load up panniers, mount lights, install fenders - anything you need for your adventure - this bike can handle it.
Dual 650b Wheels and Thru-Axles
We are the first recumbent bicycle company to offer dual 650b wheels and thru-axles. Thru-axles improve stiffness in the drivetrain, handling, cornering, and power transfer. We made these massive upgrades to the Q45’s spec to deliver even better performance and an even smoother ride. 650b wheels open up options to customize your Q45 with a huge variety of performance wheels and tires.This bike ships with 1.65 inch tires we chose for performance (even in wet weather), durability and value. And you'll still have plenty of space for fenders.
Custom-designed Handlebar
The awesome custom-designed Q45 handlebar features road styling but is sized for mountain shifters and levers. This opens a whole world of component options and also creates more space in the cockpit for better rider fit.
Q45 Recumbent Touring Bike Components
Headset |
Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.)
Shifter |
Microshift XLE 1x11 Trigger (MTB) |
Derailleur |
Microshift RD-M665M 11-speed |
Chain Wheel |
Driveline 155 42T with black anodized chain guard |
Cranks |
Driveline DX-42 155 |
Bottom Bracket |
Square Taper 68mm*113mm |
Cassette |
Microshift 11-42T |
Chain |
YBN 114 links - just one standard chain length |
Brakes |
Jagwire MC-X Mechanical Disc |
Rear Shock |
KS EXA Form 290 165 mm with external spring rated at 1200 lbs/inch |
Wheels and Tires |
650b Jet Set rims, Chosen hubs, with Maxxis Overdrive 650b x 1.65 inch tires |
Compatibility Notes
Weight
Q45 Complete: 33 lbs
Q45 Geometry
Wheelbase |
114 cm |
45.0 in |
Chainstay Length |
44.8 cm |
17.638 in |
Backrest angle |
Length of Bike (varies by adjustment and chainstay length) |
179 cm |
70.5 in |
Seat Height (measured at the low point of the seat pan, not including the cushion.) |
63.5 cm |
25 in |
BB Height (varies by adjustment and chainstay length) |
68.58 cm |
27 in |
Recumbent Touring Bike Fit
The Q45 fits riders with an X-seam between approximately 34" and 47" (approximately 5'1" to 6'4"). Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
Options
Q45 COMPLETE: The Q45 complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours.
