Cruzbike S40 2023 - Used/Returned
Ships next business day
- All sales are final
- These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches and the bike will not be packed exactly as it would be new.
- We will support you to get the bike up and running with any spare parts you may need.
- The bike and parts will have our normal warranty.
- Limited stock. When they're gone, they're gone.
- All S40 owner resources can be found here.
Cruzbike S40 2023 Recumbent Bike Tech Specs and Fit
Frame
Front Triangle
This patented drive system not only frees us from the long, inefficient chains and special parts fixed-boom recumbent bikes require, it links the upper and lower body across the drive train as it rotates around the axis of the head tube. This linkage allows Cruzbike recumbent bike riders to increase power when climbing or sprinting by engaging the upper body in much the same way professional cyclists do when they climb or sprint on traditional road bikes.
Fork
Racks and Bosses
S40 Complete Components
The 2023 S40 Complete is outfitted with a Microshift XLE 1x11 system we chose for performance and smooth shifting. The 42 tooth chainring with an 11x42 cassette hits the sweet spot for power on the flats and gearing for the climbs.
Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to make learning easier and improve handling) |
Shifter | Microshift XLE Right 11-Speed Lever for Cable Actuated Brakes |
Crankset | Driveline Crankset 165mm with 42T 110mm Narrow/Wide Chainring |
Bottom Bracket | Driveline 68mm English - External Bearing |
Cassette | Microshift G-Series 11-42T 11-Speed Cassette |
Chain | KMC X11-1 EPT Anti-Rust 1/2"x11/128" EPT |
Brakes | 160mm MCX-2 Mechanical Disc Brakes |
Wheels and Tires | 32 spoke 3 cross black aluminum rims, aero profile, tubeless compatible, 25 mm wide rim, approx 28 mm depth non-machined sidewalls, Maxxis Re-Fuse 700x32c tires |
Thru-Axles | The latest in high-end cycling axles attach the wheels more securely, are stiffer and flex less than their quick release predecessors, resulting in better power transfer and more resilience. For the new thru-axle on the S40 we chose a sleek, leverless style that even houses its own internal removal tool for the axle itself and brake rotors. |
Compatibility Notes
BB shell: English Thread 68mm
Brakes: Flat mount
Hydraulic disc brakes: The S40 2023 Frameset can be outfitted with hydraulic disc brakes using readily available long brake line kits. The exact proper length will be different for each bike/owner due to handlebar fit variations. Work with your local bike shop on this.
Weight
S40 Complete 2023: 28.6 lbs
