Ships next business day
If you want maximal power when climbing or sprinting, there is no crank length better than 145mm. Read this blog post for the technical explanation.
This 145mm Short Crank upgrade kit comes with 145mm crank arm set, 38T 1x Chainring, Bottom Bracket and 24mm Axle.
Bring this to your local bike shop for professional installation. Installation requires specialized tools and experience. Mechanics notes can be found here.
The T47 BB is compatible with our Cruzbike Vendetta V20c (Gen 1 and Gen 2).
The BSA BB is compatible with all other Cruzbike models.
Component Weights:
Click here for full details on the My Fastest Bike Guarantee program.
The Cruzbike Q45 adventure touring recumbent bicycle is built to take you and your gear wherever you want to go, as far as you want to ride.
The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
