Max Width at Shoulders: | 22.9 cm (9 in) |
Max Width at Seat: | 26 cm (10.25 in) |
Min Width: | 19.4 cm (7.625 in) |
Max Adjustable Length: | 80 cm (31.5 in) |
Min Adjustable Length: | 63.5 cm (25 in) |
Ships next business day
Click here for full details on the My Fastest Bike Guarantee program.
The Cruzbike Q45 adventure touring recumbent bicycle is built to take you and your gear wherever you want to go, as far as you want to ride.
The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
