You may also like
Cruzbike V20c
Ships next business day
Click here for full details on the My Fastest Bike Guarantee program.
- To learn more about the Complete and Frameset options, click here.
- Fit: The V20c fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Check out our blog post on how to measure x-seam here. If you are at either end of the fit range and have questions, contact us at hello@cruzbike.com. We'd love to get you fit.
Cruzbike Q45
The Cruzbike Q45 adventure touring recumbent bicycle is built to take you and your gear wherever you want to go, as far as you want to ride.
The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
Cruzbike S40
- The Gen 6 S40 ships with the Suspension Adjustable Headrest included in the box
- Fit: The S40 fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Head over here to learn more about fit. If you are at either end of the fit range and have questions, contact us at hello@cruzbike.com. We'd love to get you fit.
Cruzbike T50
NOW SHIPPING
- The T50 fits riders between 5'3" and 6'4" with a simple adjustment.
Adjustable Carbon Fiber Seat and Headrest
Fit and Specifications:
Max Width at Shoulders: | 22.9 cm (9 in) |
Max Width at Seat: | 26 cm (10.25 in) |
Min Width: | 19.4 cm (7.625 in) |
Max Adjustable Length: | 80 cm (31.5 in) |
Min Adjustable Length: | 63.5 cm (25 in) |
Includes headrest, mounting hardware and velcro. Does not include seat pad.
- Two-Piece Adjustable Carbon Fiber Seat
- All Required Mounting Hardware
- Ventisit Seat Cushion
- Headrest and Cushion
