Custom-designed wide sweep mountain handlebar for the Q45.
26” wide at the grip end and standard 22.2mm size for MTB shifters/levers, and 31.8mm clamp size.
Grip section can be cut for custom length.
Compatibility: These will work on all Q45s as a direct swap (with some re-cabling). They will also work on the S40 if you want to build your S40 up with MTB shifters and levers. Road shifters and levers are not compatible with this bar.
