Cruzbike T50
The Ultimate Recumbent Bike Cruiser
T50 Gen 3 Frameset
T50 Gen 3 Frameset
T50 Gen 3 Frameset
T50 Gen 3 Frameset
Regular price
$1,950.00
Free shipping!
In Stock
Ships in 1-2 business days
Out Stock
T50 Gen 3 Complete
T50 Gen 3 Frameset
We're confident you'll love your bike! After you've ridden it for 100 miles, if you don't love it, we'll give you a full refund on the bike including return shipping on us. Our 100 Mile Trial applies to new, full-price, complete T50, Q45, or S40 Cruzbikes purchased from the Cruzbike.com website by first-time Cruzbike owners in the contiguous United States only. For a full refund, your Cruzbike must be carefully disassembled and re-packaged in its original box according to the video instructions we provide.
View full details
This is our simplest, most elegant frame design. But don't let its simplicity fool you - it leverages more than a decade of experience making our fast, comfortable, fun-to-ride recumbent road bikes.
  • To learn more about the Complete and Frameset options, click here.
  • The T50 fits riders between 5'3" and 6'4" with a simple adjustment.
Safe city riding
Ride with great visibility
Look forward to riding with your head up, naturally and comfortably at eye level with drivers on your next foray to the coffee shop, farmer's market or local brewery.
Easily add accessories
Customize your T50 Cruiser
The T50 is ready for whatever accessories you want on your cruiser. Add a rack, panniers or a basket to carry everything from beach blankets to groceries to your laptop. Mount lights, install fenders, add a bell - you get the picture. The T50 is your canvas for creativity and cruising.
It's everything awesome about riding a bike, without the parts that hurt.
If pain is keeping you from the adventure, camaraderie and fun of cycling, you're not alone. 85% of recreational cyclists report pain in their wrists, back, neck and/or groin after a ride. (Source: International Journal of Sports Medicine). The T50 is an ergonomic bicycle that lets you sit back comfortably rather than crouch over the handlebars. This riding position saves your neck, back, wrists, groin, and quite possibly your sex life by relieving the pressure caused by the traditional bike riding position.
Recumbent Cruiser Cycling Accessories
Cruzbike T50 Tech Specs and Fit
Frame
The T50 frame is made of 7005 T6 aluminum alloy and for the new 2022 T50 it is improved for an even better ride. The main frame is now a 60mm tube (instead of 2 inch) with improved gusseting for strength. The result is an even better more positive feel on the road. We also made the rear end on the main frame e-hub capable for aftermarket electrification.
    Front Triangle
    Custom designed power triangle with telescoping inner tube plus oversized 34.9 mm outer tube for additional stiffness, constructed from quality 7005 T6 aluminum alloy.
      Adjustable Seat
      Our new seat attachment uses a proven rail system attached directly to the frame. This allows for infinite adjustment front to back, so you can find the perfect weight balance for your height and leg length.
      PLUS the 2022 T50 features the new fiber/resin seat introduced on the latest Cruzbike Q45 adventure touring bike. It delivers a fantastic compliant road feel, is half a pound lighter and one and a half inches taller than its aluminum predecessor. Pair it with Cruzbike's one piece seat cushion that cradles riders from shoulders to derrier and yep, our favorite cruiser just got even more comfortable.
        T50 Complete Components
        We chose components that balance durability and value for the T50.
          Shifter Microshift Bar End BS-A09 9 speed
          Chain Wheel Jason 38T with bash guard
          Bottom Bracket Square Taper 68mm*113mm
          Cassette Sunrace M96 11-32
          Rear derailleur Shimano Sora 9 Speed
          Chain YBN 9 speed - 120 Link
          Brakes Mechanical Disc Rever MCX02 OR Avid BB5 Caliper and Tektro CL-530 Levers
          Wheels and tires 26"*32H Double Wall Alloy rims, Duro 26x1.5" tires
          Compatibility
          Drive train: The T50 can take a very wide array of chain driven standard drivetrains. The T50 Complete is outfitted with a single chainring 1x system. With the right handlebar and stem, many mountain or even road drivetrains could be used. The Bottom Bracket Shell is a 68mm standard English thread.
          Braze-on derailleur: There is no mount point for a braze-on derailleur. A clamp on derailleur on the boom tube will work.
          Tire clearance: 2" tire maximum without fenders, 1.75" tire maximum with fenders.
            Cruzbike T50 Geometry
            Wheelbase: Throw this bike on standard racks, easily. Whether you're taking a bus, parking at a coffee shop or heading somewhere by car, the T50 is easy to bring along.
            109 cm
            43 in
            Backrest angle: Dial in the perfect seat back angle with simple adjustments.
            53 - 76 degrees
            Handlebar height:
            Adjustable
            Seat Height (low point): Feel great whether pedaling or stopped at an intersection with your feet on the ground.
            55.9 cm
            22 in
            Weight
            T50 Complete:  30 lbs. T50s built from T50 Framesets will vary with component choice.
            Fit
            Maximum X-Seam: 47-48 inches  (Click here to learn how to measure x-seam)
              Options
              T50 COMPLETE: The T50 complete ships with components pre-installed. Plan for 2-3 hours for assembly if you are a novice. Experienced mechanics will be able to complete the assembly in about 30 minutes. Ships worldwide.
              T50 FRAMESET: The essential building blocks to build (or have your local bike shop build) your next favorite bike. The T50 Frameset includes frame, front triangle, riser, stem, handlebar and seat assembly and cushion. Source your own components and have a mechanic build your T50. Ships worldwide.
              To complete your build you will need: Shifters, Cassette, Chain, Rear Derailleur, Crankset and Bottom Bracket, Pedals, Disc Brakes with Rotors, Grips, Brake Levers, 26" Wheels, Tubes, Tires, Brake Cables (Rear is a long length), Cable Housing.
              Cruzbike T50 Owner Resources
