Cruzbike Q45 Gen 5 - Unused/Damaged Box
Ships next business day
The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride. The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
- This is an unopened box. The box itself is damaged but the bike inside is brand new!
- All sales are final
- We will support you to get the bike up and running with any spare parts you may need.
- The bike and parts will have our normal warranty.
- Ships worldwide
- Limited stock. When they're gone, they're gone.
- All Q45 owner resources can be found here.
Cruzbike Q45 Gen 5 Tech Specs and Fit
Frame
Front Triangle
Suspension System
Adjustable Seat
Racks and Bosses
Dual 650b Wheels and Thru-Axles
Custom-designed Handlebar
Q45 Recumbent Touring Bike Components
Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.) |
Shifter | Microshift XLE 1x11 Trigger (MTB) |
Derailleur | Microshift RD-M665M 11-speed |
Chain Wheel | Driveline 155 42T with black anodized chain guard |
Cranks | Driveline DX-42 155 |
Bottom Bracket | Square Taper 68mm*113mm |
Cassette | Microshift 11-42T |
Chain | YBN 116 links |
Brakes | Rever MC-X Mechanical Disc |
Rear Shock | KS EXA Form 290 165 mm with external spring rated at 1200 lbs/inch |
Wheels and Tires | 650b Jet Set rims, Chosen hubs, with Maxxis Driveline 650b x 1.65 inch tires |
Kickstand | The Q45 ships with a robust, pre-installed kickstand. |
Compatibility Notes
Weight
Q45 Complete: 33 lbs
Q45 Geometry
Wheelbase | 114 cm | 45.0 in |
Chainstay Length | 44.8 cm | 17.638 in |
Backrest angle | ||
Length of Bike (varies by adjustment and chainstay length) | 179 cm | 70.5 in |
Seat Height (measured at the low point of the seat pan, not including the cushion.) | 63.5 cm | 25 in |
BB Height (varies by adjustment and chainstay length) | 68.58 cm | 27 in |
Recumbent Touring Bike Fit
The Q45 fits riders approximately 5'1" to 6'4".
Maximum X-Seam: 48-49 inches (Click here to learn how to measure x-seam)
Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
Options
Q45 COMPLETE: The Q45 complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours for assembly. We also recommend a professional pre-ride tune-up if you don't work on bikes regularly.
