You may also like
Cruzbike S40 Gen 5 Complete - Warehouse Clearance Sale Unopened
Ships next business day
These are brand new, unopened, past season stock - an incredible opportunity to get a new S40 for a wicked-low price.
- All Warehouse Clearance sales are final
- The bike and parts will have our normal warranty.
- Limited stock. When they're gone, they're gone.
- All S40 owner resources can be found here.
Cruzbike S40 Gen 5 2023 Recumbent Bike Tech Specs and Fit
Frame
Front Triangle
This patented drive system not only frees us from the long, inefficient chains and special parts fixed-boom recumbent bikes require, it links the upper and lower body across the drive train as it rotates around the axis of the head tube. This linkage allows Cruzbike recumbent bike riders to increase power when climbing or sprinting by engaging the upper body in much the same way professional cyclists do when they climb or sprint on traditional road bikes.
Fork
Racks and Bosses
S40 Complete Components
The 2023 S40 Complete is outfitted with a Microshift XLE 1x11 system we chose for performance and smooth shifting. The 42 tooth chainring with an 11x42 cassette hits the sweet spot for power on the flats and gearing for the climbs.
| Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to make learning easier and improve handling) |
| Shifter | Microshift XLE Right 11-Speed Lever for Cable Actuated Brakes |
| Crankset | Driveline Crankset 165mm with 42T 110mm Narrow/Wide Chainring |
| Bottom Bracket | Driveline 68mm English - External Bearing |
| Cassette | Microshift G-Series 11-42T 11-Speed Cassette |
| Chain | KMC X11-1 EPT Anti-Rust 1/2"x11/128" EPT |
| Brakes | 160mm MCX-2 Mechanical Disc Brakes |
| Wheels and Tires | 32 spoke 3 cross black aluminum rims, aero profile, tubeless compatible, 25 mm wide rim, approx 28 mm depth non-machined sidewalls, Maxxis Re-Fuse 700x32c tires |
| Thru-Axles | The latest in high-end cycling axles attach the wheels more securely, are stiffer and flex less than their quick release predecessors, resulting in better power transfer and more resilience. For the new thru-axle on the S40 we chose a sleek, leverless style that even houses its own internal removal tool for the axle itself and brake rotors. |
Compatibility Notes
BB shell: English Thread 68mm
Brakes: Flat mount
Hydraulic disc brakes: The S40 2023 Frameset can be outfitted with hydraulic disc brakes using readily available long brake line kits. The exact proper length will be different for each bike/owner due to handlebar fit variations. Work with your local bike shop on this.
Weight
S40 Complete 2023: 28.6 lbs
Cruzbike Q45 Gen 5 - Used/Returned
The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride. The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
- All sales are final
- These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches and the bike will not be packed exactly as it would be new.
- We will support you to get the bike up and running with any spare parts you may need.
- Ships worldwide
- All Q45 owner resources can be found here.
Cruzbike Q45 Gen 5 Tech Specs and Fit
Frame
Front Triangle
Suspension System
Adjustable Seat
Racks and Bosses
Dual 650b Wheels and Thru-Axles
Custom-designed Handlebar
Q45 Recumbent Touring Bike Components
| Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.) |
| Shifter | Microshift XLE 1x11 Trigger (MTB) |
| Derailleur | Microshift RD-M665M 11-speed |
| Chain Wheel | Driveline 155 42T with black anodized chain guard |
| Cranks | Driveline DX-42 155 |
| Bottom Bracket | Square Taper 68mm*113mm |
| Cassette | Microshift 11-42T |
| Chain | YBN 116 links |
| Brakes | Rever MC-X Mechanical Disc |
| Rear Shock | KS EXA Form 290 165 mm with external spring rated at 1200 lbs/inch |
| Wheels and Tires | 650b Jet Set rims, Chosen hubs, with Maxxis Driveline 650b x 1.65 inch tires |
| Kickstand | The Q45 ships with a robust, pre-installed kickstand. |
Compatibility Notes
Weight
Q45 Complete: 33 lbs
Q45 Geometry
| Wheelbase | 114 cm | 45.0 in |
| Chainstay Length | 44.8 cm | 17.638 in |
| Backrest angle | ||
| Length of Bike (varies by adjustment and chainstay length) | 179 cm | 70.5 in |
| Seat Height (measured at the low point of the seat pan, not including the cushion.) | 63.5 cm | 25 in |
| BB Height (varies by adjustment and chainstay length) | 68.58 cm | 27 in |
Recumbent Touring Bike Fit
The Q45 fits riders approximately 5'1" to 6'4".
Maximum X-Seam: 48-49 inches (Click here to learn how to measure x-seam)
Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
Options
Q45 COMPLETE: The Q45 complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours for assembly. We also recommend a professional pre-ride tune-up if you don't work on bikes regularly.
Carbon Fiber Chainstay (V20c) - Warehouse Clearance
- All Warehouse Clearance sales are final.
- These are returned, fully functional products. You can expect some minor scuffing or scratches.
SRAM Rival crankset, with 50/34T rings and 170mm arms, 24mm spindle
- Bolt Circle Diameter 110 mm
- Rings 2: 50 and 34
- Crank Length: 170mm
- BB Type: TruVativ GXP (BB not included)
- Spindle 24 mm GXP
- Compatible Components: SRAM 22-speed drivetrains, SRAM PC-1170 and PC-1130 chains
- Claimed Weight: [172.5 mm 52/36] 1lb 14oz (857g)
- Activity: road, cyclocross
Final sale. Warehouse Clearance sale items cannot be returned.
SRAM Rival 22 Brifter, Right, with black hood
- SRAM's lightweight alloy shifters dial in the perfect ride
- Forged aluminum sheds weight to maintain reliability and comfort
- DoubleTap shifting technology changes gears easier and faster
- Zero Loss technology enhances immediate engagement
- Reach adjust dials in the perfect lever and paddle position
- For mechanical brakes
- Claimed Weight: [pair] 11.7oz (332g)
