Cruzbike T50 Gen 3 Complete - Used/Returned
Regular price $2,650.00 Sale price $2,100.00
In Stock
Ships next business day
Out Stock
This limited inventory of used/returned stock is your opportunity to get rolling on a T50 for an incredible price.
  • All sales are final
  • These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches.
  • We will support you to get the bike up and running with any spare parts you may need.
  • The bike and parts will have our normal warranty.
  • Ships worldwide
  • Limited stock. When they're gone, they're gone.
  • All T50 owner resources can be found here.
Cruzbike T50 Gen 3 Tech Specs and Fit
Frame
The T50 frame is made of 7005 T6 aluminum alloy and for the new 2022 T50 it is improved for an even better ride. The main frame is now a 60mm tube (instead of 2 inch) with improved gusseting for strength. The result is an even better more positive feel on the road. We also made the rear end on the main frame e-hub capable for aftermarket electrification.
    Front Triangle
    Custom designed power triangle with telescoping inner tube plus oversized 34.9 mm outer tube for additional stiffness, constructed from quality 7005 T6 aluminum alloy.
      Adjustable Seat
      Our new seat attachment uses a proven rail system attached directly to the frame. This allows for infinite adjustment front to back, so you can find the perfect weight balance for your height and leg length.
      PLUS the 2022 T50 features the new fiber/resin seat introduced on the latest Cruzbike Q45 adventure touring bike. It delivers a fantastic compliant road feel, is half a pound lighter and one and a half inches taller than its aluminum predecessor. Pair it with Cruzbike's one piece seat cushion that cradles riders from shoulders to derrier and yep, our favorite cruiser just got even more comfortable.
        T50 Complete Components
        We chose components that balance durability and value for the T50.
          Shifter Microshift Bar End BS-A09 9 speed
          Chain Wheel Jason 38T with bash guard
          Bottom Bracket Square Taper 68mm*113mm
          Cassette Sunrace M96 11-32
          Rear derailleur Shimano Sora 9 Speed
          Chain YBN 9 speed - 120 Link
          Brakes Mechanical Disc Rever MCX02 OR Avid BB5 Caliper and Tektro CL-530 Levers
          Wheels and tires 26"*32H Double Wall Alloy rims, Duro 26x1.5" tires
          Compatibility
          Drive train: The T50 can take a very wide array of chain driven standard drivetrains. The T50 Complete is outfitted with a single chainring 1x system. With the right handlebar and stem, many mountain or even road drivetrains could be used. The Bottom Bracket Shell is a 68mm standard English thread.
          Braze-on derailleur: There is no mount point for a braze-on derailleur. A clamp on derailleur on the boom tube will work.
          Tire clearance: 2" tire maximum without fenders, 1.75" tire maximum with fenders.
            Cruzbike T50 Geometry
            Wheelbase: Throw this bike on standard racks, easily. Whether you're taking a bus, parking at a coffee shop or heading somewhere by car, the T50 is easy to bring along.
            109 cm
            43 in
            Backrest angle: Dial in the perfect seat back angle with simple adjustments.
            53 - 76 degrees
            Handlebar height:
            Adjustable
            Seat Height (low point): Feel great whether pedaling or stopped at an intersection with your feet on the ground.
            55.9 cm
            22 in
            Weight
            T50 Complete:  30 lbs. T50s built from T50 Framesets will vary with component choice.
            Fit
            The T50 fits riders between 5'3" and 6'4" with a simple adjustment.
              Options
              T50 COMPLETE: The T50 complete ships with components pre-installed. Plan for 2-3 hours for assembly if you are a novice. Experienced mechanics will be able to complete the assembly in about 30 minutes. Ships worldwide.
              T50 FRAMESET: The essential building blocks to build (or have your local bike shop build) your next favorite bike. The T50 Frameset includes frame, front triangle, riser, stem, handlebar and seat assembly and cushion. Source your own components and have a mechanic build your T50. Ships worldwide.
              To complete your build you will need: Shifters, Cassette, Chain, Rear Derailleur, Crankset and Bottom Bracket, Pedals, Disc Brakes with Rotors, Grips, Brake Levers, 26" Wheels, Tubes, Tires, Brake Cables (Rear is a long length), Cable Housing.
