A4x Complete Gen 1 - Used/Returned
Regular price $4,200.00 Sale price $3,800.00
In Stock
Ships in 1-2 business days
Out Stock
Cruzbike A4x Adventure Touring Recumbent Bike Key Features:
  • Dynamic Boom Front Wheel Drive — Cruzbike's patented, race-proven drivetrain engages upper and lower body for powerful climbing and efficient cruising, even under a full touring load
  • Dual-position, tunable suspension — DNM Torch DV-22 165 mm with external spring rated at 1500 lbs/inch, with dual-position mount for progressive or linear ride character and adjustable spring preload for load and rider weight tuning
  • Rearward suspension pivot — pivot sits behind the rider rather than underfoot, eliminating the vertical bounce of earlier designs for true off-pavement composure and confident tracking through technical terrain
  • Croder SPIRIT modular crankset — lightweight, precision-engineered crank system with interchangeable arm lengths, spiders, and chainrings available directly through Croder; stock spec: 155mm arm, 24mm axle, DM42T chainring (6mm offset), BSA24 steel bearing bottom bracket
  • Adjustable seatback angle — dial in your riding position between 44 and 77 degrees for the terrain ahead on the A4x's compliant, comfortable resin seat.
  • Adventure-ready rack and bag compatibility — extensive mounting options for panniers, frame bags, handlebar bags, and more; configure your carry system for any mission
  • Robust kickstand mount and stock single kickstand — the beefy and adjustable kickstand that comes stock with the A4x Complete will work for the 650b stock wheels and 24” conversion. This is really good for parking a fully-loaded bike when you pull off for a coffee. Plus, this mount is also compatible with a double kickstand for those who prefer that setup.
  • Purpose-built off-pavement frame — new heavy-duty chassis engineered for trail, gravel, and mixed-surface touring with the structural integrity to handle loaded adventure riding
  • Recumbent ergonomics — full-body comfort eliminates the wrist, neck, shoulder, and saddle pain that ends adventures early on traditional bikes
  • Generous tire clearance — stock 650b wheels accommodate tires up to 57mm (2.25") wide; swap to 24" wheels and clearance opens up to 68mm (2.6") for even more capable rubber on demanding terrain. Note: fender installation is not compatible at maximum tire width.
  • Packable for air travel —disassembles to fit inside the Tern Airporter Slim hard-shell case (with 24" wheels) at standard checked luggage dimensions, making international and fly-to-ride adventures genuinely practical
This used/returned Cruzbike A4x Adventure Touring Recumbent Bike is your opportunity to get rolling on an A4x for an incredible price.
  • All sales are final
  • These are 100 Mile Trial returns. We are not able to thoroughly check the bikes for damage, you can expect some scuffing or scratches and the bike will not be packed exactly as it would be new.
  • We will support you to get the bike up and running with any spare parts you may need.
  • The bike and parts will have our normal warranty.
  • Ships worldwide
  • Limited stock. When they're gone, they're gone.
  • All A4x owner resources can be found here.
Cruzbike A4x Adventure Touring Recumbent Bike Tech Specs and Fit
Cruzbike A4x Key Features
  • Dual-position, tunable suspension — choose progressive (forward position) or linear (rear position) shock behavior to match your terrain and load; adjustable spring preload adds fine-tuning for rider weight and carry load
A4x Adventure Touring Recumbent Bike Components
Headset Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.)
Shifter SRAM NX 1x12 Trigger (MTB)
Derailleur SRAM NX 12-speed
Chain Wheel Croder Gearmate 42T Direct Mount 6mm Offset
Cranks Croder Spirit Modular 155mm
Bottom Bracket Croder BSA Threaded Road
Cassette SRAM PG1230 11-50T
Chain SRAM Eagle 12
Brakes Tektro TRP Dual-Pull Mechanical Disc
Rear Shock DNM Torch DV-22 165 mm with external spring rated at 1500 lbs/inch
Wheels and Tires 650b Jet Set rims, Chosen hubs, with Maxxis Receptor 650b x 47c tires
Kickstand The A4x Complete ships with a robust single side, adjustable, optional kickstand and mount
Compatibility Notes
Maximum cassette width:
Front derailleur: If you choose, the A4x can accommodate a braze-on style front derailleur.
Maximum tire size: Stock 650b wheels accommodate tires up to 57mm (2.25") wide; swap to 24" wheels and clearance opens up to 68mm (2.6") for even more capable rubber on demanding terrain. Note: fender installation is not compatible at maximum tire width.
Weight
A4x Complete:
  • Without Kickstand and Mount: 35 lbs
  • Including Kickstand and Mount: 36.75 lbs
A4x Geometry
Wheelbase 114 cm 45.0 in
Chainstay Length 44.8 cm 17.638 in
Backrest angle 44-77 degrees
Length of Bike (varies by adjustment and chainstay length) 179 cm 70.5 in
Seat Height (measured at the low point of the seat pan, not including the cushion.) 64.1 cm 25.25 in
BB Height (varies by adjustment and chainstay length) 68.58 cm 27 in
Recumbent Adventure Touring Bike Fit
Maximum X-Seam: 48-49 inches (Click here to learn how to measure x-seam)
The A4x fits riders approximately 5'4" to 6'4".
Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
Options
A4x COMPLETE: The A4x complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours for assembly. We also recommend a professional pre-ride tune-up if you don't work on bikes regularly. The A4x Complete ships worldwide
