Ships in 1-2 business days
MOUNT YOUR REAR LIGHT, CAMERA, OR OTHER LIGHTWEIGHT ACCESSORIES.
The Cruzbike Utility Post is an add-on product for the Headrest Cage Mount Kit or the Race Cage. It adds a standard seat tube diameter post that allows you to mount your rear light, camera, or other lightweight accessories onto the headrest cage mount or the back of the race cage. The mounting tabs are standard bottle cage spacing. Note: the Utility Post for the Race Cage has higher price due to additional hardware included for mounting.
PRODUCT DETAILS
Weight: 3.5 oz
Height: 15 cm
Compatibility: All V series models, S40, Silvio, S30 - requires Headrest Cage Mount Kit to be mounted to the rear headrest.
INSTALLATION GUIDE: Headrest Cage Mount Kit and Utility Post Add-on
Gen 6 sees the return of SRAM. The SRAM components we have chosen deliver excellent performance and are our favorite S40 build yet. We also upgraded to full compressionless cable housing for both the front and rear brakes. Some components - the Cane Creek Viscoset, KMC chain, our proven reliable hubs - are proven to last and return once again to grace this beautiful frame.
| Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to make learning easier and improve handling) |
| Shifter | SRAM APEX 1x11 Road |
| Crankset | SRAM Apex 165 w/ 110 BCD Narrow Wide Ring (1X) 42T chainring |
| Bottom Bracket | SRAM GXP |
| Cassette | SRAM 11-42 |
| Chain | KMC X11-1 EPT Anti-Rust 1/2"x11/128" EPT |
| Brakes | TRP Spyre Dual Piston |
| Wheels and Tires | 32 spoke 3 cross black aluminum rims, aero profile, tubeless compatible, 25 mm wide rim, approx 28 mm depth non-machined sidewalls, Maxxis Re-Fuse 700x32c tires |
| Thru-Axles | The latest in high-end cycling axles attach the wheels more securely, are stiffer and flex less than their quick release predecessors, resulting in better power transfer and more resilience. For the new thru-axle on the S40 we chose a sleek, leverless style that even houses its own internal removal tool for the axle itself and brake rotors. |
BB shell: English Thread 68mm
Brakes: Flat mount
Hydraulic disc brakes: The S40 Frameset can be outfitted with hydraulic disc brakes using readily available long brake line kits. The exact proper length will be different for each bike/owner due to handlebar fit variations. Work with your local bike shop on this.
| Complete | 29. 3 lbs (includes pedals, cushions and headrest) |
| Frameset | 15 lbs (final weight of custom built frameset will vary based on component choice.) |
| Mainframe | 5.3 lbs |
| Handlebar | 0.65 lbs |
| Cushions, handlebar wrap, through axles, headset and clamps: | 1.65 lbs |
| Chainstay and chain stay clamps | 0.75 lbs |
| Boom and slider with pivot clamp and boom clamps | 2.1 lbs |
| Headrest | 0.55 lbs |
| seat with extension and hardware | 2.45 lbs |
| Wheelbase | 1130.3 mm | 44.5 in |
| Chainstay length - standard | 450 mm | 17.75 in |
| Rake (front fork offset) | 30 mm | 1.2 in |
| Head tube angle (steering axis) | 71 degrees | |
| Trail | 91.44 mm | 3.6 in |
| Backrest angle | 40 degrees | |
| Length of Bike (varies by adjustment and chainstay length) | ||
| Seat Height (low point) | 609.6mm | 24 in |
| BB Height (varies by adjustment) |
The S40 fits riders with an X-seam between 35 inches and 48 inches (about 5'2" to 6'5" body height). Check out the 2021 S40 Fit video here and head over to our Fit page for more great resources on fit.
This used/returned Cruzbike A4x Adventure Touring Recumbent Bike is your opportunity to get rolling on an A4x for an incredible price.
Dynamic Boom Front Wheel Drive — Cruzbike's patented, race-proven drivetrain engages upper and lower body for powerful climbing and efficient cruising, even under a full touring load
Dual-position, tunable suspension — choose progressive (forward position) or linear (rear position) shock behavior to match your terrain and load; adjustable spring preload adds fine-tuning for rider weight and carry load
Rearward suspension pivot — pivot sits behind the rider rather than underfoot, eliminating the vertical bounce of earlier designs for true off-pavement composure and confident tracking through technical terrain
Croder SPIRIT modular crankset — lightweight, precision-engineered crank system with interchangeable arm lengths, spiders, and chainrings available directly through Croder; stock spec: 155mm arm, 24mm axle, DM42T chainring (6mm offset), BSA24 steel bearing bottom bracket
Adjustable seatback angle — dial in your riding position between 44 and 77 degrees for the terrain ahead on the A4x's compliant, comfortable resin seat.
Adventure-ready rack and bag compatibility — extensive mounting options for panniers, frame bags, handlebar bags, and more; configure your carry system for any mission
Purpose-built off-pavement frame — new heavy-duty chassis engineered for trail, gravel, and mixed-surface touring with the structural integrity to handle loaded adventure riding
Recumbent ergonomics — full-body comfort eliminates the wrist, neck, shoulder, and saddle pain that ends adventures early on traditional bikes
Generous tire clearance — stock 650b wheels accommodate tires up to 57mm (2.25") wide; swap to 24" wheels and clearance opens up to 68mm (2.6") for even more capable rubber on demanding terrain. Note: fender installation is not compatible at maximum tire width.
Robust kickstand mount and stock single kickstand — the beefy and adjustable kickstand that comes stock with the A4x Complete will work for the 650b stock wheels and 24” conversion. This is really good for parking a fully-loaded bike when you pull off for a coffee. Plus, this mount is also compatible with a double kickstand for those who prefer that setup.
Packable for air travel —disassembles to fit inside the Tern Airporter Slim hard-shell case (with 24" wheels) at standard checked luggage dimensions, making international and fly-to-ride adventures genuinely practical
| Headset | Cane Creek ViscoSet® Headset (This premium headset leverages viscous damping to inhibit exaggerated movement of the front end for easier learning and off bike handling.) |
| Shifter | SRAM NX 1x12 Trigger (MTB) |
| Derailleur | SRAM NX 12-speed |
| Chain Wheel | Croder Gearmate 42T Direct Mount 6mm Offset |
| Cranks | Croder Spirit Modular 155mm |
| Bottom Bracket | Croder BSA Threaded Road |
| Cassette | SRAM PG1230 11-50T |
| Chain | SRAM Eagle 12 |
| Brakes | Tektro TRP Dual-Pull Mechanical Disc |
| Rear Shock |
DNM Torch DV-22 165 mm with external spring rated at 1500 lbs/inch |
| Wheels and Tires | 650b Jet Set rims, Chosen hubs, with Maxxis Receptor 650b x 47c tires |
| Kickstand | The A4x Complete ships with a robust single side, adjustable, optional kickstand and mount |
Maximum cassette width:
Front derailleur: If you choose, the A4x can accommodate a braze-on style front derailleur.
Maximum tire size: Stock 650b wheels accommodate tires up to 57mm (2.25") wide; swap to 24" wheels and clearance opens up to 68mm (2.6") for even more capable rubber on demanding terrain. Note: fender installation is not compatible at maximum tire width.
A4x Complete:
| Wheelbase | 114 cm | 45.0 in |
| Chainstay Length | 44.8 cm | 17.638 in |
| Backrest angle | 44-77 degrees | |
| Length of Bike (varies by adjustment and chainstay length) | 179 cm | 70.5 in |
| Seat Height (measured at the low point of the seat pan, not including the cushion.) | 64.1 cm | 25.25 in |
| BB Height (varies by adjustment and chainstay length) | 68.58 cm | 27 in |
Maximum X-Seam: 48-49 inches (Click here to learn how to measure x-seam)
The A4x fits riders approximately 5'4" to 6'4".
Check out the fit graph in the blog post here to see where you land. If you are close to the outside of the fit range, please contact us at support@cruzbike.com.
A4x COMPLETE: The A4x complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours for assembly. We also recommend a professional pre-ride tune-up if you don't work on bikes regularly. The A4x Complete ships worldwide
The Q45 adventure touring bike is built to take you and your gear wherever you want to go, as far as you want to ride. The Q45 features our patented dynamic boom front wheel drive powertrain so you can climb fast in a perfectly comfortable seated riding position. It has super smooth suspension, a robust packable aluminum frame with the ability to use wider tires. Options for rack systems allow you to carry everything you need for wherever the road (or path) takes you.
| Shifter | Microshift XLE 1x11 Trigger (MTB) |
| Derailleur | Microshift RD-M665M 11-speed |
| Chain Wheel | Driveline 155 42T with black anodized chain guard |
| Cranks | Driveline DX-42 155 |
| Bottom Bracket | Square Taper 68mm*113mm |
| Cassette | Microshift 11-42T |
| Chain | YBN 116 links |
| Brakes | Rever MC-X Mechanical Disc |
| Rear Shock | KS EXA Form 290 165 mm with external spring rated at 1200 lbs/inch |
| Wheels and Tires | 650b Jet Set rims, Chosen hubs, with Maxxis Driveline 650b x 1.65 inch tires |
| Kickstand | The Q45 ships with a robust, pre-installed kickstand. |
Q45 Complete: 33 lbs
| Backrest angle | ||
| Seat Height (measured at the low point of the seat pan, not including the cushion.) | 63.5 cm | 25 in |
The Q45 fits riders approximately 5'1" to 6'4".
Q45 COMPLETE: The Q45 complete ships with components pre-installed. Experienced mechanics will be able to complete the assembly in about 30 minutes. For those of us who don't work on bike regularly, plan for 2-3 hours for assembly. We also recommend a professional pre-ride tune-up if you don't work on bikes regularly.
This limited inventory of used/returned stock is your opportunity to get rolling on a T50 for an incredible price.
| Shifter | Microshift Bar End BS-A09 9 speed |
| Chain Wheel | Jason 38T with bash guard |
| Cassette | Sunrace M96 11-32 |
| Rear derailleur | Shimano Sora 9 Speed |
| Chain | YBN 9 speed - 120 Link |
| Brakes | Mechanical Disc Rever MCX02 OR Avid BB5 Caliper and Tektro CL-530 Levers |
| Wheels and tires | 26"*32H Double Wall Alloy rims, Duro 26x1.5" tires |
Wheelbase: Throw this bike on standard racks, easily. Whether you're taking a bus, parking at a coffee shop or heading somewhere by car, the T50 is easy to bring along. |
109 cm |
43 in |
Backrest angle: Dial in the perfect seat back angle with simple adjustments. |
53 - 76 degrees |
Handlebar height: |
Adjustable |
Seat Height (low point): Feel great whether pedaling or stopped at an intersection with your feet on the ground. |
55.9 cm |
22 in |
T50 Complete: 30 lbs. T50s built from T50 Framesets will vary with component choice.
T50 COMPLETE: The T50 complete ships with components pre-installed. Plan for 2-3 hours for assembly if you are a novice. Experienced mechanics will be able to complete the assembly in about 30 minutes. Ships worldwide.
T50 FRAMESET: The essential building blocks to build (or have your local bike shop build) your next favorite bike. The T50 Frameset includes frame, front triangle, riser, stem, handlebar and seat assembly and cushion. Source your own components and have a mechanic build your T50. Ships worldwide.
To complete your build you will need: Shifters, Cassette, Chain, Rear Derailleur, Crankset and Bottom Bracket, Pedals, Disc Brakes with Rotors, Grips, Brake Levers, 26" Wheels, Tubes, Tires, Brake Cables (Rear is a long length), Cable Housing.
60mm depth rims, tubeless ready clinchers, center lock disk brake hubs and rim brake compatible built up with White Industries CLD hubs with the 24/28 spoke count, Shimano 11-speed free hub. Comes mounted with PG-1170 11-36T cassette and Conti 700cx25mm tubeless tires. Also one 160mm rotor (needs another one). These are skewer wheels
All warehouse clearance items are final sale.
was added to your cart!
